126coupe's Avatar
She Blew Up!
Blew up bigtime at CA Speedway this weekend. Just finished tearing it down. heres what happened.... #6 rod bolt let go. (Carillo Rods) Boy those rods are strong It took out the case, the oil pump. the cylinder, the crank( std, knife edged ect) the piston, also when the rod broke the piston collided w the valves and broke the rocker arm........ metal everywhere..F..........
Any methods on how to clean my front coolers and many oil lines?
I dont mind sending out the coolers.
It gave no warning Just lost a cylinder oil light flicker and it was all over. No holes in the case but........... a mess
I'll post pictures of the mayhem
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 02-16-2004, 07:57 PM
Did you get the memo?
onewhippedpuppy's Avatar
Ouch! I'll tip a 40 to it's memory. Now it's 3.6 time!
‘07 Mazda RX8-8
Old 02-16-2004, 08:00 PM
126coupe's Avatar
Photos of the rod bolt failure
28' Pace Trailer
Old 02-16-2004, 08:18 PM
John Rogers's Avatar
I did that last year with my 914 stroker four which is why I put in a six. My temp sender on the bottom of the case went into the pits near the start-finish line...... The pictures looked just about the same!
Old 02-16-2004, 08:53 PM
911ctS's Avatar
Send a message via Yahoo to 911ctS
Oh man................such a tough break, wait..................wait...........ok I said my prayer.
so sorry to see this carnage of what looked to be a very well thought out and built engine. I can see the boat tailing of the case and the knife edged crank....oops nevermind im just making it worse. give my condolences to your surviving parts and long live the memories of the dead.
Except that bastard of a rod bolt.
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 02-16-2004, 08:54 PM
Administrator
Jack Olsen's Avatar
Ouch. Sorry to hear about it.
The truth is, it could happen to any of us, at any time.
Old 02-16-2004, 09:09 PM
Zeke's Avatar
I did some serious damage to a 4 cyl last year and the metal you mention is indeed a problem. What I did was burn a piston, so hot metal went thru the motor, lines and coolers. The engine cooler was tossed. The deal there was that the metal was still hot enough to stick to the interior surfaces. The lines I had were Earl's and are smooth inside, so a rigorous flushing cleaned them up nicely. I haven't yet tended to the front mounted cooler, but I think that the metal was cool enough by the time got up there that a super cleaning will do the job.
Old 02-16-2004, 10:22 PM
Senior Member
Doug Zielke's Avatar
My stomach is strong.....
Some (sharp) close-ups of those pistons, cylinders and rods would be much appreciated.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-17-2004, 07:32 AM
126coupe's Avatar
my digital camera i have is over 5 years old having trouble w closeups. time for a new camera
28' Pace Trailer
Old 02-17-2004, 07:39 AM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
Man, tough break...literally. I cant imagine that the case is salvagable. What's next?
Matt
'82 911SC Targa!
Old 02-17-2004, 07:44 AM
Eric Mckenna's Avatar
Did she give you any warnings?? any signs she was dying on the way to or before the track day?
or did it just .. Go? I am sorry to hear of this ...
well I see a 3.6 coming.. hahahah
eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 02-17-2004, 07:45 AM
126coupe's Avatar
This race engine has been reliable for 5 years, refreshened at 35-45 hours yearly. no bearing wear at all at 45 hours! this engine had 38 hours on it. i hold 20 quarts of oil and run 200-210 degrees on the hottest days at willow sp. CA Speedway is tough on engines I was hammering it hard on fri and sat ( 8400 rpm's in the oval section in 5th) No warning, oil light flicker and lost a cyl Then I shut her down. Lost the case, crank ect. what a mess $$$$$$$$$$$$$$$$ have all the parts to build my 2.5 now!
28' Pace Trailer
Old 02-17-2004, 07:59 AM
126coupe's Avatar
oh i forgot to mention this was all caused by a rod bolt failure. i replace the carillo rod bolts w every refreshen.
28' Pace Trailer
Old 02-17-2004, 08:00 AM
Plavan's Avatar
Wow- sorry about the big loss Mark. I those damn rod bolts. My dad has the California speedway curse X 2. Two engines now were the victims. We will be tearing his motor apart this week. We will have more carnage photos.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-17-2004, 09:31 AM
MMARSH's Avatar
Wow, sorry about the engine. Those pictures are bringing back bad memories. I lost a rod bolt in a freshly built 3.4 a couple of years ago. Did the same damage plus a big nasty hole in the top of the case.
Oh, I had my front oil cooler ultrasonicly cleaned. don't know any of the details, I sent it to my wrench and he took care of it. I've since reinstalled it and have been running it for almost two years without any issues.
Michael
Old 02-17-2004, 12:47 PM
banjomike's Avatar
OH MAN!! and I just ate lunch!
Do a search on oil cooler and cleaning. There was a thread last year about ultrasonic techniques used in airplane oilcoolers.
I wonder if frequent replacement of rod bolts increases the chances of installing one with a flaw (or making a mistake on installation)?
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 02-17-2004, 12:55 PM
