-   -   i need a trick. fan nut. HELP! (http://forums.pelicanparts.com/porsche-911-technical-forum/149745-i-need-trick-fan-nut-help.html)
vash 02-20-2004 04:26 PM
i have no idea how the damn thing got so tight! i have taken it off several times without issues. it is like some gorilla got into my garage and torqued it down. i have the two pronged pcar tool that pokes into holes in the pulley. then i use a standard halfinch drive and i apply gobs of pressure. i bent the pulley tool! i need a trick please! i am trying to get the alt out to continue troubleshooting. do i need to fabricate a sturdier tool? very frustrating.
cliff
ZOA NOM 02-20-2004 04:28 PM
Lefty-loosey, righty-tighty. :)
ubiquity0 02-20-2004 04:28 PM
Can you get a length of steel pipe that slides over the pulley tool fairly snuggly & adds a little length for leverage. If its snug enough it might prevent the tool bending more as well. & you know for best leverage you need to 'squeeze' the pulley tool & the driver together right?
vash 02-20-2004 04:30 PM
ok, wise guy. :)
by the way, can i switch over to the pulley that uses the spanner tool? i think it is for the newer cars? i hate that piece of crap two pronged tool. it is a major knucklebuster waiting to happen. i will happily toss the airpump in order to do so.
ZCAT3 02-20-2004 04:30 PM
If you can find another person to help and have a large hollow 2 piece handle from your floor jack then you can put each part of the handle over the wrench and the pulley tool. One of you hold the pulley tool in place, while the other leverages the wrench. That should do it and be careful not to over tighten when you put it back (and keep the gorilla out of your garage).
Joe Bob 02-20-2004 04:31 PM
Air gun....hopefully you have one or access to one that can do 175+ psi....bet the shaft is cross threaded. DAPO did that to me on one.....suxz.
vash 02-20-2004 04:38 PM
let you show you what i mean by bent!
it bent this way! i hope the threads are not wasted. the few i see poking past the nut look good. i cant friggen believe that i may have to take my car to a pro for a fan belt nut! no i dont have an air gun....
http://forums.pelicanparts.com/uploa...1077323909.jpg
ZOA NOM 02-20-2004 04:38 PM
Sorry, couldn't resist.
I have nothing constructive to offer, so I chose humor.
vash 02-20-2004 04:39 PM
that tool is crap, it is only about 10" long! how much leverage can i put out? help me....
vash 02-20-2004 04:40 PM
believe me, it was funny. you almost made me doubt myself! haha
ZOA NOM 02-20-2004 04:43 PM
yeah, we know you went and tried the other way.
vash 02-20-2004 05:19 PM
no, but i thought about it.
JP911 02-20-2004 05:24 PM
I would soak the nut with a little PB blaster and let it sit overnight. If you've already bent the factory tool, then applying more leverage with a cheater bar really won't do much except bend it more. One trick that may work is to whack the rachet with rubber mallet a few times to generate some impact (like an impact air gun might).
yelcab1 02-20-2004 05:31 PM
Dude, go to a gas station with an impact. OR, come to my house across the bay, I have an impact air gun (among other interesting tools)
vash 02-20-2004 05:44 PM
thanks yelcab, i dont think an impact gun can get to it. the back panel of the car will get in the way. these car are haunted, at least mine and onewhippedpuppy's are. it is running strange,(having a hard time idleing). i swear i spent money on the car, i dont know why it is pissed. haha. my pcar mech said to bring it in and he will show me a trick. i promise to pass it on. i am going to switch it over to the other pulley that uses the spanner wrench, i hate that cheapo two prong thing. i am going to toss it off a bridge. hope i dont choke a passing sealion.
greglepore 02-20-2004 05:49 PM
It'd be very hard to get to that nut with an air gun, unless you're an artist with a universal. The jackhandle trick worked for me about a month ago, but if you bent a factory tool, you must be a gorilla, or its hopeless. Yank it and put in a 3.6.
vash 02-20-2004 05:52 PM
ok, this is the second time i just laughed my arse off, in my downer moment. i will get a 3.6! thanks greg.
definately makes eyeballing a newer car easy. hahah
effen frozen on nut......
DavidI 02-20-2004 05:57 PM
By the way you bent the tool, could you be the gorilla?
Just trying to be funny.....
vash 02-20-2004 06:29 PM
i could be the gorilla, i think diane fossey is kinda cute.
(this joke will suck, if i got the name wrong. was it diane goodall?)
Zeke 02-20-2004 06:42 PM
This is the 1st intelligent answer so far to a real problem. I too, bent the tool. Ceratainly, if I had a cheater bar, I could destroy the tool. What needs to be done is get the nut off.
Unfixed, I have heard that heat applied to the nut along with some sharp whacks will nudge the nut. You should have a new belt on hand as the heat will not do the old one any good. Whenever I heat something, I try to anticipate what collateral damage I might do. So, I try to provide a heat sink just beyond what needs to be heated. In this case, a wet towel warped around the pulley itself would help.
Of course, this is all theory at this point as far as mine pulley nut goes. Haven't had the time to get back to that job. If I do it, I will post a follow up.
