Licensed User
jmz, the cluster itself isnt really rusted but its going to get the POR treatment as soon as I can get it apart. There was some surface rust on the floorpan where it bolts up to though. I just scraped and cleaned that area as much as possible, vacuumed it out, prepped with the POR15 Metal Ready, and painted with POR15. Hopefully it will hold up
Shuie, is that one of them "RS" factory lightweight rear shelfs?
Matt
'73 911 Targa / 2.7 RS spec |
Hi JMZ: My first Porsche was killed by rust, I won't let my '69 be killed by RUST! Listen to all of these great advise. I will say that the culprit was the rear window gasket. In order to find out all for real you must dissasemble all the rear seats, carpet, rear shelf, panels, seat belts, etc... to see all the damage. The seat area and both corners are real problems area. hopefully all has only surface rust. I have used several rust preventive paints they all did not work so great with the exception of POR15. The Wurth type undercoating is a bear to remove. use a hot gun, I do not have one, so I used a propane torch, but my car is all torn apart, no tank, fuel, etc... and a small scraper, You must remove all the undercoating since water posible has gone underneath and appears ok from the outside, but there is rust underneath. Take a close look at the photos previously posted, that is wahat normally happens. Use a metal scraper, then a drill with a wire brush and remove all rust scales to see how much damage the rust has made. Then we will see how we ATTACK and DESTROY! the Porsche worst enemy. Take care and do not give up!
Did you get the memo?
I had a leaky rear window seal, damage a little worse than yours, but not much, and I was amazed how much surface rust was under that stupid floor coating. My wife's hair drier and a scraper was all it took to get it up, then I wire brushed the rust, used a grinder and wire wheel on the painted parts, and POR'ed the whole damned thing. No worries, now I have to do the front seat area.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
As Shuie mentioned, use the POR-15 Metal Ready primer before the POR-15 coating. POR-15 is meant to go right on the rust after you get the loose stuff off. If you clean it down to bare metal you want to use the primer first.
Hey, jmz - I've got the perfect solution for you:
Since the rust has not eaten through, sand it to knock off the loose rust. Then, go down to Pep Boys and buy a can of Extend and spray on a coat - let it dry - and spray on another coat. I guarantee you won't have to worry about it again.
1982 Porsche 911SC Coupe 1999 Porsche 911/996 Coupe |
Look ma...no rust...
I have been removing all the factory sound deadening and tar paper to completly un-cover any rust. So far, I have removed about 50 lbs of stuff and only found some minor surface rust around the seams in the rear lid. I am one of the luck owners who is still searching for the rust. By the way, it is a '69. -Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
While cleaning my 911 this afternoon, I noticed that my floor mats were damp... under those, my carpets were wet... under those, the floors were soaked. At first glance though, the factory wax covering still looked perfect until I started prodding with a screwdriver. Needless to say, I ended up ripping all of the waxy stuff out and found a ton of surface rust on my driver's side rear floorpan!!!
No holes though... whew... and I wailed on it with my pointiest screwdriver too.![]() ![]() Luckily, the other three pans still look great but I'll definitely need to clean up that rusty one. The next step is searching for where the water got in... since it's the rear pan, I'm suspecting the rear window seal.
1979 911SC "Frankencab" Dave |
What in the hell are those two circular things on the sides of the rear floorpan? I've been meaning to ask ever since I did mine.
I think they're drain plugs.
Hearing so many early porsche rust stories is one of the main reasons I wanted a late 80s model. I figured there has to be some pretty good rust protection behind that corrosion warranty they had.
Gon fix it with me hammer
mine was also supposed to be rustfree when i bought her last august. then the honeymoon was over
today we're in couples therapy:
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Heck, I’m only 5 not 71!
I welded my "U" shaped cuts closed and ground down the weld bead. on the inside floor pan I lead soldered over the "U".
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
That is "light surface rust" if most ads are anything to go by.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
19 years and 17k posts...
John,
Those are the same ads that always say something like "_____is broken, but can be easily fixed". If that were true wouldn't they have fixed whatever it was before they tried to sell it?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Unregistered
I've heard those holts were there to give access to the spot welders during assembly. They were there befroe they started galvanizing so that's out.
1979 911 SC Targa http://www.pelicanparts.com/gallery/Mike_Kast |
oh yeah, i'm quite obsessive / posessive about her
in return, she's plundering my bank account ![]()
