-   -   Help Getting Axle In (http://forums.pelicanparts.com/porsche-911-technical-forum/149827-help-getting-axle.html)
North Coast Cab 02-21-2004 10:11 AM
I took both axles off to repack cv's and am having trouble getting back in. The passengers side went in fairly easy. I can't get the drivers side to fall into place. I have the shock disconnected and have tried raising the control arm with no luck. Is there a trick?
John
North Coast Cab 02-21-2004 10:18 AM
If you grab the passengers side axle you are able to move the axle shaft back and forth consistently within the two cv joints as designed. The drivers side is rock solid and there is no movement of the axle shaft or flexibility of the cv joint. I rechecked assembly and everything seems in order. I can't see how a failing cv or axle would cause this to happen. ??????????
John
Tim Polzin 02-21-2004 10:46 AM
I think you may have re-assembled the CV joint incorrectly. If the grooves (or what ever you call the slots where the ball ride) are incorrectly matched, it will have no movement.
Tim
North Coast Cab 02-21-2004 12:09 PM
I've taken everything apart again and reassembled. I even flipped the outer ring to see if by chance it was backwards. For simplicity, the cv is made up of three basic components. There is an inner ring which is attached to the axle end, and middle ring which houses the 6 bearings, and an outring. I tilt the middle ring about 30 degrees and them slide on the outer ring at an opposite 45 degrees. Once in place the middle ring can move in and out a little, but the outer ring is solid. It doesn't seem to have the flexibility needed to handle the upward and downward movement of the wheel and axle. This is why I can't get it to conform to the angles needed at the wheel and tranny to get into place.
John
Tim Polzin 02-21-2004 01:51 PM
This post may be dealing with the same problem.
http://forums.pelicanparts.com/showthread.php?s=&threadid=31589&highlight=axle+re assembly
Tim
Sonic dB 02-21-2004 01:59 PM
ot....so glad I paid my mechanic $250 to do the CV boots and regrease last week. Good Luck North Coast!
North Coast Cab 02-21-2004 02:17 PM
It's messy but basically very easy, other than this issue. They were 1/2 off for the engine drop so it just made sense. Still frustrated though.
John
Early_S_Man 02-21-2004 02:45 PM
Here is another thread with scans from a VW Bentley manual on the Lobro CV-joint assembly and disassembly procedures ...
http://forums.pelicanparts.com/showthread.php?s=&threadid=62514&highlight=disasse mbly
Tim Polzin 02-21-2004 02:54 PM
That's the one I was looking for. Knew I had seen it, but could not find it. Thanks Waren!
Tim
North Coast Cab 02-21-2004 03:14 PM
Got it. I slid e outer ring off and rotated it one slot over. Once back on it rotates like crazy. Thanks for the help.
John
