Temperature sensor
Ok, i was about to install my new temp sensor onto the engine when i noticed that the connection at the top of the sensor is different from the one it's replacing. The one on the motor has a wierd dish looking head, while the new one has a regular male eletrical fitting. The part number of the new one is 911 606 112 00 and pet shows both this part number and another, 901 641 632 00. Can someone shed a little light on this for me?
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix ![]() |
Is the gauge numbered or not???
The second, older p.n. you listed is for the numbered gauge. The round 'mushroom cap' style Faston post is designed to relieve strain on the wire for any angle, but the older tab style works just fine on the older sensors!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
So the sensor came in both that dish looking cap and the male electric connector? Mine car doesn't have the number gauge for oil temp, so this is the correct temp sensor. But that different style connection throws me off.
1fastredsc, I just changed both the gauge and the temp sender on my 83SC. The temp sender that I removed was like yours with a male connection. The replacement had the dish style. It worked with no problem at all.
On a side note, my gauge read that my car was running very hot. Another Pelicanhead asked me if the temp sender unit and the gauge matched. I was not sure, so I decided to change them prior to spending a bunch of money on external coolers. With the new matching parts, my car now gives an accurate reading in the 190 degree range.
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
hmmm, that makes me curious now as to whether that was my issue with the car reading 240-250 on steady cruises.
1fastredsc, I bet that would solve your problem. It did for me.
Good luck, David
Thread Tools | |
Rate This Thread | |
