Alarm siren location
Hi Guys & Gals,
I am getting an alarm installed in my '82 Coupe and would like to know where the best location to mount the siren is? I have heard that mounting it in the front of the car or in the cabin drowns out the sound of the siren considerably.
I was thinking of either the underside of the turbo wing or the right side of the engine bay (next to the air con)
Any suggestions?
Blitzkrieg
82 911 SC Coupe
Old 03-01-2004, 02:07 AM
dram's Avatar
Get a high pitch, high db siren and mount it inside the cabin. It will lower the sound level a bit, except for inside the car where the thief is. There it will be deafening, actually painful if you have the right siren.
Don
'87 911 Carrera Coupe
Old 03-01-2004, 04:56 AM
When I had my alarm redone the guy used a siren I had laying around...here's where he put it. Sound carries pretty well.
Warren & Ron, may you rest in Peace.
Old 03-01-2004, 05:08 AM
Binge User
Schrup's Avatar
The factory installed mine next to my fuel pump, attached to the front crossmember. It is protected by the skid plate in that location & was fairly loud. I think I'm going to relocate it in the trunk near the vent opening.
Paul
Old 03-01-2004, 05:14 AM
Cool
the alarm brain puts out around 1 amp, check alarm paperwork.
1 amp is enough to operate a relay.
From the relay can be attached an electrinic siren and an air horn compressor that will get noticed.
PS: don't overload the brain or Kaput
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-01-2004, 09:43 AM
87turbolook911's Avatar
I second the post for putting a high freq. siren inside, Under the dash where it is hard to get to...
It makes it extremely uncomfortable for those thieves wishing to visit your car while your're away. The sirens on the outside don't get much attention nowadays....better yet do both....just be sure to use relays or you will fry the alarm brain.
It's not just the cars...It's the people...
Porsche Club of America
NoVa / DC / MD Porschephiles
Porsche911FactoryTurbo-LookCars
Old 03-01-2004, 10:33 AM
Slantnose Huckleberry
courtc2911's Avatar
I recently purchased an 82 SC (with a Code Alarm after market system) and am having problems with the siren(s). They just love to go off while I'm sitting at stop lights or am cruising down the freeway. I had a shop rip it out but all they could pull was the the brain and wiring. They couldn't find the siren(s), and they still go off!
The sirens are not mounted inside the car as it is not very loud to my ears, but I can tell it is to others outside the car, as everyone looks...
Does anyone have any idea where I can locate these damn things? They must be removed and crushed before causing any more embarrassment!
82 Slantnose
Old 05-05-2008, 05:44 PM
I was able to cram two Hella Twin Supertone horns in the factory location next to the steering rack, above the skid plate. It took a lot of trial and error, and refitting, but it works GREAT. Those horns cause the ground to vibrate. They are run on a relay and consume 100watts each.
Old 05-05-2008, 06:32 PM
falcon's Avatar
I believe the original location for the installed stock horn on my 88 is in the left rear quarter in the engine compartment against the side. It appears that part of the black plastic cover was cut away to allow the horn to fit.
Randall
1988 911 Cabriolet (SW Chip)
2000 Honda Civic (4dr wifey mobile)
2001 Honda S2000 (daily driver)
2003 Honda Odyssey (family truckster)
1978 911 SC coupe (Sold)
My 911 Cab Pics
Old 05-05-2008, 06:49 PM
courtc2911's Avatar
I appreciate the feedback!
I have to say, it sounds like the siren(s) is up in the front.
Hmmm, next to the steering rack, above the skid plate? Does anyone have a pic of this area? I am new to P-cars and am not sure how to access certain areas. How would I find this area?
Thanks.
82 Slantnose
Old 05-05-2008, 07:31 PM
3.2 CAB's Avatar
Have you checked under the front, at the fenders, bumper, valance, etc? You will have to have power going to it, so you should be able to trace the wires to the noise maker.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-06-2008, 11:14 AM
mppickett's Avatar
I put the alarm control in the trunk under the driver side fender and the siren near the battery. I configured it to honk the horns as well as to sound the siren. Since I've got a cabrio it makes it a little less likely that someone could disable the alarm than if it were under the dash.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 05-06-2008, 04:04 PM
