Senior Member
ohecht's Avatar
Need Heater Hose Solution
Can someone help me with a source for more flexible, heat resistant hose for this connection? I don't know if the PO had the pass-through moved, but there is no way the OEM replacement will stay in place, and the one that was there is lost.
Here is the connection:
Here is the attempt with the OEM hose. It looks cool, but is under tension and will not stay. I hate these metal/paper hoses!
Thanks in advance,
Olivier
Olivier Hecht
1982 911SC
Old 03-03-2004, 06:42 PM
Who is John Galt?
Rondinone's Avatar
There should be a 90-degree bend made from sheet metal right above your heat exchanger. Let me see if I can get a photo of mine.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 03-03-2004, 06:51 PM
North Coast Cab's Avatar
Not sure of the OD, but the brake cooling hoses available are very durable and heat resistant. Try OG Racing, I think they have 2 1/2" & 3".
John
1985.5 944 GTS
Who is John Galt?
Rondinone's Avatar
Here you go. That poor coiled hose is one pathetic sight!
'79 911sc Targa
'84 Tamiya Falcon
Old 03-03-2004, 06:54 PM
Senior Member
ohecht's Avatar
Tha 90-degree bend looks familiar, now that I see it. Maybe I will look around for it some more! My garage is a mess after 2 months of projects.
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 03-03-2004, 06:58 PM
the old style exchangers aimed the hose thru a hole in that little square filler piece of tin, at the end of the chain housing. you would also need the early air outlet off the fan housing, but that would require backdating the heater system. that 90° piece in the pic would be the ticket otherwise. standard SC stuff, but it needs to be trimmed at the end to allow the short section of hose to fit.
206 637 4071
Old 03-03-2004, 10:08 PM
Senior Member
ohecht's Avatar
I can't find that piece anywhere, which is strange even given the mess I made. I still had all the parts in one place. I have been considering back dating anyway, since my blower motor finally died a few months ago. I think I have SSIs, and the hole going through that piece of tin realy looks home-made.
Would the same flexible hose used between the exchangers and the flapper boxes work here? The ones I got from Pelican are very flexible and could probably make this connection directly.
Olivier
Olivier Hecht
1982 911SC
Old 03-04-2004, 04:17 AM
Check out the other post recently about heater hose's. The paper/aluminum foil hoses are not very good in unprotected areas under the engine and will quickly fail. A SCAT or silicone impregnated hose is very flexible to not only allow flexing but also avoid damage from stone chips. The black one pictured has been in place for 3 years with no damage.
Old 03-04-2004, 04:35 AM
Senior Member
ohecht's Avatar
That looks like what I got for the flapper boxes. I think I will use that instead, since it is so flexible and durable.
It took me twice as long to connect all those paper hoses as it did to reinstall the actual engine!
Olivier
Olivier Hecht
1982 911SC
Old 03-04-2004, 05:16 AM
Friend of Warren
Oliver, I have two of those hoses that I bought and didn't use. Will sell them to you cheap if you want them!
Kurt V
Old 03-04-2004, 07:30 AM
Use high quality SCAT or SCEET from Aircraftspruce and specialty Supply... the web page is written similary but I don't have it in fornt of me. Hi-temp silicone with copper coated wire...in either single or double thicknesses and various diameters...great stuff.
---Wil Ferch
EDIT: http://www.aircraftspruce.com/catalog/appages/scat.php
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-06-2004, 07:25 AM
Senior Member
ohecht's Avatar
Thanks, Will. I need to get some hoses for the connection to the blower inside the engine compartment, too. I am sick of those crappy paper hoses that don't fit, don't bend, and tear too easily.
Olivier
Olivier Hecht
1982 911SC
Old 03-06-2004, 03:40 PM
Gordo2's Avatar
Backdate
Olivier,
Go for the backdate. I just did it on mine. Looks much better and the easier access to the engine is the real pay-off. Total cost $60 for the old style ducts, you can't beat it.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-06-2004, 07:29 PM
Steve W's Avatar
Thanks to you guys, I bought scat hose from a local aircraft supply shop so I could rehookup my heater for which the crappy aluminum ones I had would keep falling apart. I was told it was supposed to withstand 600 degrees F. I had to squash the hose in the tight space between my cam covers and muffler for my right side SSI, so the entire side of one hose is flat against the muffler, right by the intake. So my question is, can the stuff withstand the highest surface temps of a muffler without melting or something?
Old 03-06-2004, 08:28 PM
Steve, first off, the Bodymotion SSI heater duct leaves much to be desired in the placement of the hoses. If your set up is like my old one was with this duct, the hose comes in direct contact with the muffler. I would venture to guess that it is over the temp range for SCAT. I used a reducer on the end of the bodymotion pipe and the SSI to gain some clearance. You live in a warm climate, go with a backdate and just get rid of all that mess!
Old 03-06-2004, 09:37 PM
Steve W's Avatar
Michael, it does look like a mess - plus the Bodymotion pipe isn't exactly aligned well and hangs low. This is my last attempt, and I think I will do a full backdate if this doesn't work.
Old 03-06-2004, 10:29 PM
Senior Member
ohecht's Avatar
Gordo,
Do you have a parts list and source for the $60 backdate?
I have been considering it strongly, since my blower motor finally died for good after many repairs, and I do not need massive heat. I thought the parts were more like $150-$200, though.
Easy engine access is key for me, since I seem to adjust something during every drive!
Thanks,
Olivier
Olivier Hecht
1982 911SC
Old 03-07-2004, 05:10 AM
