H.G.P.'s Avatar
Range of movement on my windsheild wiper arms are going crazy
When I work the wipers, on the first several swipes, the movement is ok, thereafter, they go out of sequence, and the drivers side even swipes beyond the windshield. Can/should/ and/ or how, are the range of movement corrected? Thanks.
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 03-05-2004, 02:06 PM
Flip open the cover plate to the wiper arm nuts and check to see if they are tight. You may need to replace the arms if the knurling inside the arms is worn and not contacting the hold down screw tight enough.
Old 03-05-2004, 02:34 PM
Senior Member
Superman's Avatar
Yeah, something sounds loose, and that would need to be fixed right away.
Mocha 1978 911SC. "Coco"
Old 03-05-2004, 02:39 PM
3.2 CAB's Avatar
I had to rebuild my wiper assembly a couple of years ago. They would go where ever they wanted to sort of. I found the flat elbow that connects from one side to the other broken straight through the middle of the mounting hole. I got a good used assembly and put my new motor on it. I took the "new" one apart and lubed everything up then reassembled it with the new motor. Works great since then.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-05-2004, 02:44 PM
H.G.P.'s Avatar
One of the exterior "cap nuts", the one on the passenger side, it appears needed to be tightened. I tightened it, and both arms appear to be working fine now.
One other question, after using the wipers, after immediate use, they do not finish at the very very bottom of the windshield, somewhat higher. I'd like them to finish at the bottom. Any solution to this? Thanks
1969 911 E Coupe
Old 03-07-2004, 01:44 PM
re-position the wiper arm after removal
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2004, 02:22 PM
