Gordo2's Avatar
How to tell if you have broken head studs during a valve adjustment
These fall out or sit in the hole!!
Mine today, outside # 1 and # 3 on exhaust side. Had mentally prepared for it, assuming I had some broken studs, so I'm not too bummed.
Question: The nuts fell out separated from the studs (not screwed onto the stud). Only one stud came out, is it possible the other stud is still intact? I can't see into the hole, its behind the cat converter.
Gordo
BTW 1st valve adjustement went well. No more clacking, how nice.
Don "Gordo" Gordon
'83 911SC Targa
Old 03-05-2004, 09:03 PM
I had one of these loose nuts myself, and at first thought it was ok.....screw it back on and you will likely see you can thread it all the way on, and not actually be able to torque it down.....as if the head stud is pulled out a bit.....it is likely a pulled headstud...or in the process of being a pulled headstud....
Old 03-05-2004, 09:45 PM
djmcmath's Avatar
Glad to hear the valve adjust went well. Bummer about the head stud, though. Have you read the most recent head-stud advice thread? Head stud brocken, now what
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 03-06-2004, 07:57 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I thought SCs did not suffer from pulling head studs.
1981 SC ROW Coupe
Old 03-06-2004, 08:10 AM
they don't. use a mirror to see better.
206 637 4071
Old 03-06-2004, 08:42 AM
Doug E's Avatar
Hey Don - you know what I just went through as a result of my broken 3 studs. PM here or on the NoVa board and I'll give you my home number if you want to talk it through.
Doug
'81 SC Coupe
Old 03-06-2004, 01:25 PM
