Lorenfb's Avatar
Yes, your temp sensor values are backwards. S/B as many have posted,
a high value when cold and a low value hot. If your readings are correct,
then you've found the problem.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 03-11-2004, 08:42 PM
North Coast Cab's Avatar
I listed them backwards.
Hot 647ohms
Cold 3500ohms
I'm rechecking the ISV and I don't get the voltage readings suggested. On the connector I get 12v between middle and one outer terminal and nothing between the middle and the other one. Also, I tried to hear and feel the ISV run with the ignition switch on and don't get anything. On the ISV itself I get .39ohms from 1 to 3 and that's it.
Can you fully outline the testing procedure for the ISV?
John
1985.5 944 GTS
Old 03-12-2004, 03:55 AM
