-   -   MSD..Yes or No?..... (http://forums.pelicanparts.com/porsche-911-technical-forum/152269-msd-yes-no.html)
fred cook 03-07-2004 03:20 PM
Ok folks, I'm getting close to plunking down my hard earned cash and buying an ignition system. The car this hardware is going on is a 1980 911SC. Right now my first choice is the MSD-6A or 6AL box to replace the Bosch CDI that went to the big electronic graveyard in the sky. The wiring looks pretty straight forward and no permanent changes are required. Like they say at a wedding, "Does anyone know of any reason this car and this electronic gizmo should not be joined in mechanical wedlock?"
All opinions and thoughts will be appreciated!
Thanks,
Fred Cook
'80 911SC coupe (oops, already said that didn't I!)SmileWavy SmileWavy SmileWavy SmileWavy SmileWavy SmileWavy
chuckw951 03-07-2004 03:25 PM
Well the MSD would be more expensive than buying a used CD box. I sold one a while back for $125 or so. Easy to replace and you are back on the road.
Lorenfb 03-07-2004 04:03 PM
Pelican Parts has rebuilt Bosch CD units. You can find them by doing a Pelican
search under "cd rebuilt". The Search box is at the bottom of the Porsche
Page.
Replacing the Bosch CD is a much easier approach than rewiring for
a different unit, e.g. hookup, & tach. The performance difference is
insignificant.
blue82coupe 03-07-2004 04:14 PM
You can purchase an MSD 6AL from Summit Racing for about 200.00 Dollars. In my opinion It's a worthwhile investment. Dan
Rouxzy 03-07-2004 04:17 PM
Performance differance is insignificant? Obviously you haven't switched from the original to an MSD. I did and the engine idles much better, and runs and has more power in the lower end of the rpm scale. I will agree that top end will not be changed but the lower end will show a significant differance. Buying a used CD is just that, it's used and may quit on you the next day. These of course are just my own personal experiences. Do a search here and you'll find that going the MSD route is worth it.
Tom
blue82coupe 03-07-2004 04:32 PM
Ditto
pwd72s 03-07-2004 04:47 PM
Here we go again! FWIW, I've chosen to remain with the factory CD unit....but MSD fans are MSD fans because Permatune has so many drawbacks...;)
A Quiet Boom 03-07-2004 04:50 PM
Well the 6al gives you the "soft touch rev limiter" which most engine builders will tell you is a very nice thing to have. I run a 6al on my SC engine along with an MSD programmable timing computer and locked out advance in the distributer, make for a very nice setup.
47silver 03-07-2004 05:24 PM
i have the msd and after i installed a pertronix and never (knock on wood) have trouble starting the car.
the po put the msd in and i put the pertonix....
no experience with the bosch.
gary
Steve W 03-07-2004 05:27 PM
Soft touch - sounds like a good thing for the rod bolts :)
dhoward 03-07-2004 05:30 PM
Very happy with my MSD.
RoninLB 03-07-2004 06:10 PM
you may need a tach adaptor. and if you have ignition noise with the MSD let me know.
I also re-wired the whole stock cocky poo ignition system.
I posted the job last Oct or Nov.. it's pretty wild.
Howard M 03-07-2004 06:19 PM
I, too, am happy with my MSD + Pertronix ('76 911S). Easier starting and smoother idle. I don't think you need the Pertronix because of your magnetic "points" (my year was the last for conventional points). If you go MSD, also plan on the MSD High Vibration Coil and think about new ignition wires too (Magnecor), because of the higher voltage resulting from the larger plug gap allowed. The only semi-challanging part of the MSD installation is the adapter plate needed to mount the MSD unit onto the (smaller) original CD footprint. Make one out of cardboard and then reproduce it in 3/16 aluminum. You may also have to move the accumulator, slightly. I also recommend the dial programmable MSD rev limiter, rather than the individual, single RPM "pills". Have fun, it's a rewarding project to do yourself.
Howard
Howard M 03-07-2004 06:24 PM
I forgot to mention, you DON'T need a tach adapter. Don't use the MSD tach signal output to your tach. Continue to use your points output wire to signal your tach AND as the input signal for the MSD box. In other words, don't break the points output wire, just "tee" into it to provide the input signal to the MSD box.
H20911 03-07-2004 08:30 PM
I went with crane cames High 6 and pulled an MSD 6al out.
http://www.cranecams.com/?show=msdCrossReference
Do what you want.
http://forums.pelicanparts.com/uploa...1078723763.jpg
I use this one and it has many more features than the MSD.
http://www.cranecams.com/pdf/90006400a.pdf
al lkosmal 03-07-2004 09:33 PM
i have the MSD6A an pertronix ignitor installed on my 77S. works great!!!. I noticed that Mallory now has a unit that appears to be an MSD clone. I.E same bolt pattern, for approx $100. no experience with the Malory but $100.......worth a try.
hugo454 03-08-2004 03:03 AM
electromotive, nothing beats getting rid of the distributor,cap & rotor.
JackT 03-08-2004 03:39 AM
I thought the benfit of the MSD was the higher RPM's on pre 911SC's. At least on 911SC's and up there does not seem to be any benefit. It may idle smoother with the MSD, but I do not see how it would perform better than stock up to red line on a 911SC and up.
avendlerdp 03-08-2004 06:40 AM
I just went through this on my 1970 T. I still am firing the MSD with points though. The performance increase at low rpm's was VERY significant. The Msd is true to it's name and fires multiple sparks with each cycle. This really helps ignite the mixture at idle and off idle. It was super east to install as well. Considering that you can spend $200 on a shift boot this seems like a Porsche bargain.
Alex
jmz 03-08-2004 07:54 AM
MSD, great with a car with carbs but why would you really need it on a properly tuned stock CIS car?
dhoward 03-08-2004 07:59 AM
You probably wouldn't.
H20911 03-08-2004 08:23 AM
You really would not. Once the flame is lit it really would not matter if you put more sparks behind it.
MSD only gives multiple sparks up to 3K which would explain why cars idle better (particularly if they are not tuned perfectly).
If MSD was so great it would be on evey car. I only chose crane due to its digital functions and more features that a stock ign would not have.
jmz 03-08-2004 08:31 AM
It was more or less a rhetorical question. I have to say, I like my msd on my modified 3.0 though.
RoninLB 03-08-2004 08:39 AM
it should help out a old rings and valves below 3k..
it did on a beat 350 Chevy
MikeBogue 03-08-2004 08:45 AM
gary
I would check out that pertronix a little closer. I had one in an old Volvo and I found an 8 degree variation if I rotated the magnet on the distributer lobe. I ordered another magnet assembly, because they said they never had that problem and that assembly had a 10 degree variation.
fred cook 03-08-2004 08:58 AM
Cooking with MSD...
To try to answer some of the questions posed above:
Does a Porsche CIS in good working order run well? Certainly!
Did Porsche and Bosch spend lots of time and money designing the stock CDI unit? Of course!
Do Porsche or Bosch EVER do anything halfway? Of course not!
Was the original type Bosch CDI designed over 25 years ago? Yep
Has there been any progress in electronic component/ignition design since then? I hope so!
Is a "rebuilt" unit better than or as good as a new one? Good question.
As much as I respect the engineering that went into not only my Porsche but also all the others, sometimes I like to "see" if there could be an improvement made. If the opportunity presents itself, the change can be made without ruining anything and the price is right, then why not give it a try? In this particular case, the original CDI went "belly up" and a repair is required. The cost of a rebuilt Bosch CDI is fairly expensive running anywhere from $250 up to $400. The Perma-tune which seems to be a fairly close copy of the Bosch unit (with some power upgrades) is also in the $300-$400 range. The MSD and the Crane Hi6 units offer the benefits of a CD type ignition with extras thrown in. The low (under 3000 rpm) speed multi-spark design should be beneficial and the $200 price tag makes it an attractive choice. Plus, as I said to start with it can be installed without "butchering" the wiring system. The last plus is that now I can also send the Bosch unit off for repair and keep it on the shelf as a spare!
Fred Cook
'80 911SC coupe
Lorenfb 03-08-2004 09:19 AM
Check out this web site (www.systemsc.com) on the Technical page
under Ignition Systems for some additional info.
Lorenfb 03-08-2004 05:17 PM
The HC (hydrocarbons) level, a measure of unburned fuel, can be used
as a comparative indicator of the effectiveness of an ignition system.
Since the HC level is a key emissions test parameter, the use of
multiple sparks to reduce the HC level by major OEM car manufacturers
would be universal. Also, if the claim for added performance were true,
this would be another benefit of using a multiple spark system.
The added technical complexity and cost of utilizing multiple sparks is
very minimal. Thus, based on these key facts, a multiple spark ignition
system has little to no benefit over a single spark ignition system.
Oldporsche 03-08-2004 05:44 PM
If I had the perfect world of a perfectly tuned digital fuel injection system, perfectly matched to the cam and timing, pehaps with variable valve timing, etc. What ever ignition system designed to go with the above would be the only way to go.
Unfortunately, this isn't a perfect world, and those of us with carbs can only have reasonable hope of an rpm range that they will perfectly work in.......the MSD often helps the carbs.
Good luck,
David Duffield
fred cook 03-08-2004 06:23 PM
Missing the point.....
First let me state that I appreciate very much that so many of you Pelicanites have taken the time to post replies on this thread. Also, I fully support the fact that everyone is welcome to their opinions, but..... I can't help but believe that some are missing a very important point here. That is, the ignition system that Porsche chose to equip my 1980 vintage automobile with was developed somewhere along about 1973 or so. That make the technology approximately 30 years old. In this day and age when an electronic gizmo (i.e. computer) can become obsolete in 6 months, I simply have to believe that improvements in ignition systems have been made since the Bosch CDI was designed. Since the CDI unit in my car has ceased to function, I have spent a fair amount of time researching various options available as a replacement. I will say that had the CDI unit in my car continued to function, I would have simply left it alone since the performance was quite satifactory. However, it failed and that has provided me with the oportunity to try something new. Since my wallet is not fat enough to change over to a distributorless system, I am limited to trying to make my remaining hardware work as well as possible. The $200 or so that this mechanical adventure will cost is both affordable and expendible. That is, if for some reason I simply can't stand the way my car runs with the MSD ignition, then I will move on to something else. One of the BIG pluses that I see is that I will still have the Bosch CDI box, should be able to get it repaired and will have a working spare on the shelf. Meanwhile I will have my car back on the road where I can enjoy it to the fullest.
Thanks,
Fred Cook
'80 911SC coupe (soon to vroom, vroom)
H20911 03-08-2004 06:48 PM
Fred.....pick what you want...I read an article in Hot Rod that did a comparison between Crane and MSD and I think that Jacobs was in there too. The out come was a huge eye opener where all the tests were within 1 % of each other. this did not shock me ( because of advertising $$$$). features such as start retard, nitrous timing retard, Boost retard....etc are the only reasons other than $$$$. MSD will work great for you and I hear if the box craps out you can send it to MSD for a total rebuild for about $60.00 ...quite a bargin indeed ;)
A Quiet Boom 03-08-2004 07:57 PM
Yes, This is an awesome feature and one of the main reasons MSD boxes are in the majority on drag and circle track cars among others. Simply put the "soft-touch" system pulls the spark from a different cylinder on each rotation to slow down the engine without allowing the cylinders to overfill with fuel which can be very bad. On drag cars a two-step or three-step box is used. My drag car had the MSD 7AL3 box with three rev limiters. I used the primary for max engine rpm, the second for regulating my burnout rpm and the third for launch. A launch rev-limiter is also know as a "stutter-box" because that's the way it sounds. Here's the rundown on how they're used, I think you'll see why they are so well liked. At the starting line in a stick-shift car the driver engages the starting line rev limiter, pushes in the clutch and FLOORS the pedal, the rev-limiter is usually triggered by a button on the wheel or stick shift, when the tree drops the driver just releases the button and the clutch at the same time, the engine is at the chosen rpm (usually above 5000rpm) at wide open throttle so the launch is brutal yet deadly accurate. If you think that's crazy I know some guys who also launch with stage one of a multistage nitrous system engaged still being held by the MSD soft touch. In other words if it can protect those high dollar engines and safely hold them at speed it's going to be real gentle to your P-car! Another feature that most racers like is that the rev limit is set with "pills" corresponding to the correct rpm so theire no need to free rev the engine while looking at the tach to adjust some stupid little knob.
I've used MSD on nearly every car I've had in the last 15 years with the exception of my brand new Ranger 4x4 and it will eventually get one as well.
As mentioned elswhere in this thread to mount the coil in the stock location you'll also need the high vibration coil which can be mounted upside down. Here is a pic of my install.
http://forums.pelicanparts.com/uploa...1078808264.jpg
The box on the back wall is the Programmable timing computer, I locked out the stock advance in the distributer and use the box to set the advance curve that works best with my modified Zeniths (36mm venturis on my SC engine)
JackT 03-09-2004 04:23 AM
Fred,If I were in your shoes, I would replace with a modern, reasonbly priced aftermarket box. I misunderstood earlier in this thread. I was thinking you were pulling a healthy stock box and replacing with a MSD. My point was it would not make a huge improvment over stock. I think the MSD and other modern systems are better than stock and a lot cheaper. I run the MSD 6AL on 2 V8 engines and love it. I never foul out plugs with the MSD. They idle better but there is not a perfomance gain with the MSD over the stock setup, when the stock setup is properly tuned. The stock setup just didnt stay properly tuned long, without the MSD.
jmz 03-09-2004 05:58 AM
QUOTE:..."I can't help but believe that some are missing a very important point here...
not really missing the point, you asked a yes or no question. My opinion is that there isn't really much benefit to the MSD over a stock Bosch CDI unit on a properly tuned CIS car.
On a nasty fuel spitting High Compression Carbeurated car I think the MSD helps. ...these cars are harder to keep in perfect tune than a stock CIS car and the MSD compensates for that.
QUOTE: "Was the original type Bosch CDI designed over 25 years ago? Yep
The MSD 6AL is over twenty years old itself
QUOTE: "Has there been any progress in electronic component/ignition design since then? I hope so!"
The MSD isn't what I would call a technological marvel or even a modern ignition system. The MSD 6AL is over twenty years old itself.
I think the MSD 6al is a decent spark box and has served me well. I don't think there is a need for it on a stock CIS car and I would just plug in a BOSCH box. This way you don't have to drill any holes, make a new wire harness or worry that your MSD craps out on you down a lonely stretch of road.
fred cook 03-09-2004 08:11 AM
Yawl, Y'all
JMZ
How bout posting a picture of the 37' Yawl. I bet it is a real looker!
Thanks,
Fred Cook
'80 911SC coupe
PS I really wasn't trying to argue those points, just present my train of logic.
Early_S_Man 03-09-2004 08:39 AM
Fred,
All of the MSD 'advocates' seem to be in a bit of a 'cloud of confusion' ... comparing a new MSD installation to a stock CDI system with problems -- that they chose not to fix!
As jmz points out ... there is no improvement in power or drivability over a stock CDI system with clean grounds and power connections, and good trigger (green) cable, and good ignition cables ... all of which are usually done with the MSD downgrade [almost] everyone raves about!
JWW has had good luck with the Permatune unit for SCs, and I have no experience with that six-pin box to say yay or nay about it!
My best guess is that it would take under two hours to fix your Bosch CDI ...
All we are talking about is replacing the following $1.00 2N3055 transistor, and replacing some 20 or so solid point-to-point wires with new ribbon cable for resistance to fractures in the future.
http://forums.pelicanparts.com/uploa...1078853928.jpg
jmz 03-09-2004 08:44 AM
Fred, You don't have to encourage me much to talk about boats.
Here are a few pics of SHARED WATCH.
...to keep it sort of on topic, their is nothing better for me than driving my old loud car down to the bay to go for a sail.
http://forums.pelicanparts.com/uploa...1078854079.jpg http://forums.pelicanparts.com/uploa...1078854099.jpg http://forums.pelicanparts.com/uploa...1078854122.jpg
fred cook 03-09-2004 02:05 PM
Y'alls Yawl....
Wow! Nice boat. I used to do a little sailing many years ago. It is really relaxing to just sort of luff along and listen to the waves slap the hull while contemplating a bottle of really good beer!
Warren,
I do plan on fixing the Bosch CDI. However, I have this insatiable, insane NEED to "fiddle" with my car. The boxes of bits and pieces (from previous automobiles) that reside in my garage are mute testimony to this fact. Usually I will show great restraint until something (like the Bosch CDI) quits working at which time I do my homework and "create" a car project. The last such project involved replacing the main fuse holders with modern "flat" fuses. It would have been much simpler to replace the fuse blocks with OEM parts, but where is the fun in that? The important thing is to go about these projects in a way that does not compromise the reliability or the "restorability" (new word) of the car. I guess I just got to be me!
Fred Cook
'80 911SC coupe SmileWavy
A Quiet Boom 03-09-2004 05:31 PM
The Bosch CDI may be a great unit, but MSD is certainly not a downgrade. I'll agree that maybe they're about the same on a stock vehicle but once you start doing things like bigger cams, more compression, turbos and the like the added features of MSD become real attractive. I'd say they're a must on a serious racecar and pretty important on a hot street car. Let's face it MSD systems were designed for the rigors of serious street machines and full on race cars, calling them a downgrade in relation to a Bosch unit is a bit of an overstatement. Besides when an accident like a missed shift or broken driveline part happens would your rather trust a stock rev-limiter designed only to be used in emergencies or one that was specifically designed to be used as a tool for racing? Personally I used the MSD components in my car because one I already had them and two the programmable timing computer allowed me to tune the advance to my carbs without having an outside shop recurve my distributer. I swear by MSD and until something better comes along that is also affordable in relation to the cost of the engine I'll continue to swear by them. I lost races with my drag car from broken input shafts, fried main bearings, twisted crankshafts, shattered driveshafts, broken rocker arms, etc. but never due to an ignition failure. And after my car sat outside in the snow all winter (I know sacrelige) I rapped the gas pedal a few times and it started right up, not bad for a car with a set of carbs and no cold start circuit or chokes.
fred cook 03-17-2004 11:07 AM
Here are some pictures of the MSD installation in my SC:
http://forums.pelicanparts.com/uploa...1079553955.jpg http://forums.pelicanparts.com/uploa...1079553987.jpg http://forums.pelicanparts.com/uploa...1079554006.jpg
