fred cook's Avatar
Cool MSD..Yes or No?.....
Ok folks, I'm getting close to plunking down my hard earned cash and buying an ignition system. The car this hardware is going on is a 1980 911SC. Right now my first choice is the MSD-6A or 6AL box to replace the Bosch CDI that went to the big electronic graveyard in the sky. The wiring looks pretty straight forward and no permanent changes are required. Like they say at a wedding, "Does anyone know of any reason this car and this electronic gizmo should not be joined in mechanical wedlock?"
All opinions and thoughts will be appreciated!
Thanks,
Fred Cook
'80 911SC coupe (oops, already said that didn't I!)
Old 03-07-2004, 04:20 PM
chuckw951's Avatar
Well the MSD would be more expensive than buying a used CD box. I sold one a while back for $125 or so. Easy to replace and you are back on the road.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 03-07-2004, 04:25 PM
Lorenfb's Avatar
Pelican Parts has rebuilt Bosch CD units. You can find them by doing a Pelican
search under "cd rebuilt". The Search box is at the bottom of the Porsche
Page.
Replacing the Bosch CD is a much easier approach than rewiring for
a different unit, e.g. hookup, & tach. The performance difference is
insignificant.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 03-07-2004, 05:03 PM
blue82coupe's Avatar
You can purchase an MSD 6AL from Summit Racing for about 200.00 Dollars. In my opinion It's a worthwhile investment. Dan
Old 03-07-2004, 05:14 PM
Rouxzy's Avatar
Performance differance is insignificant? Obviously you haven't switched from the original to an MSD. I did and the engine idles much better, and runs and has more power in the lower end of the rpm scale. I will agree that top end will not be changed but the lower end will show a significant differance. Buying a used CD is just that, it's used and may quit on you the next day. These of course are just my own personal experiences. Do a search here and you'll find that going the MSD route is worth it.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 03-07-2004, 05:17 PM
Ditto
Old 03-07-2004, 05:32 PM
pwd72s's Avatar
Here we go again! FWIW, I've chosen to remain with the factory CD unit....but MSD fans are MSD fans because Permatune has so many drawbacks...
Old 03-07-2004, 05:47 PM
A Quiet Boom's Avatar
Well the 6al gives you the "soft touch rev limiter" which most engine builders will tell you is a very nice thing to have. I run a 6al on my SC engine along with an MSD programmable timing computer and locked out advance in the distributer, make for a very nice setup.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 03-07-2004, 05:50 PM
47silver's Avatar
i have the msd and after i installed a pertronix and never (knock on wood) have trouble starting the car.
the po put the msd in and i put the pertonix....
no experience with the bosch.
gary
1975 911S Targa
Silver Anniversary Edition
Old 03-07-2004, 06:24 PM
Steve W's Avatar
Soft touch - sounds like a good thing for the rod bolts
Old 03-07-2004, 06:27 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Very happy with my MSD.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 03-07-2004, 06:30 PM
Cool
you may need a tach adaptor. and if you have ignition noise with the MSD let me know.
I also re-wired the whole stock cocky poo ignition system.
I posted the job last Oct or Nov.. it's pretty wild.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2004, 07:10 PM
I, too, am happy with my MSD + Pertronix ('76 911S). Easier starting and smoother idle. I don't think you need the Pertronix because of your magnetic "points" (my year was the last for conventional points). If you go MSD, also plan on the MSD High Vibration Coil and think about new ignition wires too (Magnecor), because of the higher voltage resulting from the larger plug gap allowed. The only semi-challanging part of the MSD installation is the adapter plate needed to mount the MSD unit onto the (smaller) original CD footprint. Make one out of cardboard and then reproduce it in 3/16 aluminum. You may also have to move the accumulator, slightly. I also recommend the dial programmable MSD rev limiter, rather than the individual, single RPM "pills". Have fun, it's a rewarding project to do yourself.
Howard
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-07-2004, 07:19 PM
I forgot to mention, you DON'T need a tach adapter. Don't use the MSD tach signal output to your tach. Continue to use your points output wire to signal your tach AND as the input signal for the MSD box. In other words, don't break the points output wire, just "tee" into it to provide the input signal to the MSD box.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-07-2004, 07:24 PM
H20911's Avatar
I went with crane cames High 6 and pulled an MSD 6al out.
http://www.cranecams.com/?show=msdCrossReference
Do what you want.
I use this one and it has many more features than the MSD.
http://www.cranecams.com/pdf/90006400a.pdf
Old 03-07-2004, 09:30 PM
al lkosmal's Avatar
i have the MSD6A an pertronix ignitor installed on my 77S. works great!!!. I noticed that Mallory now has a unit that appears to be an MSD clone. I.E same bolt pattern, for approx $100. no experience with the Malory but $100.......worth a try.
RGruppe #669
http://www.x-faktory.com/
Old 03-07-2004, 10:33 PM
hugo454's Avatar
electromotive, nothing beats getting rid of the distributor,cap & rotor.
Old 03-08-2004, 04:03 AM
I thought the benfit of the MSD was the higher RPM's on pre 911SC's. At least on 911SC's and up there does not seem to be any benefit. It may idle smoother with the MSD, but I do not see how it would perform better than stock up to red line on a 911SC and up.
Old 03-08-2004, 04:39 AM
avendlerdp's Avatar
I just went through this on my 1970 T. I still am firing the MSD with points though. The performance increase at low rpm's was VERY significant. The Msd is true to it's name and fires multiple sparks with each cycle. This really helps ignite the mixture at idle and off idle. It was super east to install as well. Considering that you can spend $200 on a shift boot this seems like a Porsche bargain.
Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 03-08-2004, 07:40 AM
jmz jmz is online now
jmz's Avatar
MSD, great with a car with carbs but why would you really need it on a properly tuned stock CIS car?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-08-2004, 08:54 AM
