jacking... creaking... squeeking
hi all,
jacked up my newly aquired T last weekend. This is probably a dumb question, byt I was just wondering if its normal to hear some creaking and squeeking on the way up? Should I be worried about this.
Also, just to let you know, I did like many other pelicanites i have read about... Even after reading all the warnings, I spilled oil all over the garage floor while doing the first oil change. Oil container was large enough, but the hole for the oil to enter wasn't. Turned a quick and easy job into a two hour ordeal. I had to run to the store to buy kitty litter. Oh well, live and learn. Even with the setback, I had fun doing it. Its been awhile since I've worked on my own car, and I forgot how enjoyable it is.
Cheers
John
Old 03-10-2004, 02:52 PM
126coupe's Avatar
My racecar squeaks and creeks, but there is not a
rubber bushing anywhere
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-10-2004, 02:54 PM
so could it be a matter of worn motor mounts?
John
Old 03-10-2004, 02:55 PM
126coupe's Avatar
Try and narrow it down to the front or the rear
of the car, Motor mounts........doubtful
28' Pace Trailer
Old 03-10-2004, 02:56 PM
it was coming from the rear. i didn't really try to isolate it. could have been from the rear suspension, maybe elsewhere. but i'm pretty sure it was coming from the rear half of the car.
John
Old 03-10-2004, 03:00 PM
126coupe's Avatar
my educated guess would be torsion tube bushings
28' Pace Trailer
Old 03-10-2004, 03:01 PM
Torsion bars will make a similiar sound as you jack it up and down.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 03-10-2004, 03:02 PM
thanks for the quick respnses minkoff. i'll try to figure out exactly where the noises come from next time i get the car off the ground. thanks, i love this board.
John
Old 03-10-2004, 03:04 PM
126coupe's Avatar
Good Luck!
28' Pace Trailer
Old 03-10-2004, 03:05 PM
oh yeah, if it is the either of these things mentioned, is it something I should be worried about? thanks
John
Super Moderator
cstreit's Avatar
Neither are dangerous, but will affect performance and warrant replacement at some point.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-10-2004, 03:12 PM
goliver's Avatar
Could it just be that a targa will creak a bit. My old car (targa) always creaked when jacked up. the door wouldnt close properly etc. If you don't think they flex, gingerly place your finger in the gap left between the top of the door panel and the dash while driving in your drive way or over some bumps. Be careful not to stick your finger in too far or you will get quite a pinch.
Cheers,
Geoff
Geoff Oliver
'99 C2 Cabriolet
Old 03-10-2004, 03:40 PM
