Optical trigger to replace points on a 68?
Whats involved with this? Any recommendations for the right unit to use?
Is there any way to get a car once converted to work with the stock tach, or am I looking at the cost of a new tach on top of the cost of the other equipment?
1968 911L 2004 Dodge Dakota SLT Plus |
There is a system like this on my L. It was intalled when I bought the car so I can't comment on the installation, but it is a pretty simple looking system. I have gone through the whole set-up process, and that is pretty straight forward also. As far as I can tell there is no special stuff for the tach signal since the stock coil is maintained.
Joe 1993 C2 |
Dotorg;
That's the same system that I've got on my car too.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Hmmmm. Pelican says you need a new tach. Maybe I'll order it and see what happens. I already have two coils and assorted spaghetti pile of wiring to get the tach working, how much worse can it get? ;-)
I'm using/installed a CRANE XR700 optical on both my cars.
See Ya points! not at all hard to do just bring the crank to TDC (Top Dead Center) follow the rest of instructions. I have heard the infarred eye can dirty. Never had the problem. As for the Tach, if you hook it up, it will register spurattic. I would think Pelican sells the Crane Tach adapter as well. With the adapter no proplems.
67 Normale "Old Rusty" 67 Rennen inspired 73 ST Caged Beast RGruppe #383 |
i've got the xr700 on a 67 engine, in a 70 914-6.
pretty easy install, i had no problems with my tach, no adapter. i'm using the xr700 to trigger the bosch cdi, if that makes any difference. doug waters
doug waters 70 914-6 dougwatersfotos.com http://www.flickr.com/photos/dougwatersfotos/ |
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I've also got the XR700 on mine; it was installed a few years ago, and I've had no problems yet with orignal tach. Fairly easy to do, though I had a little bit of trouble fitting the round shutter on. Say goodbye to points and a jumping tach!
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Navin Johnson
just a tach adapter.... you could of course buy a new tach if you wanted too.. I know of a car that has had an Allison..nee Crane optical trigger in it.. it has been in use for almost 20 yrs.. its set and forget. It can be used to trigger the Bosch CD, or a more modern MSD or Crane ignition box.. The setup was installed by me in my car in the early 80's I sold the ignition to a fellow a few yers ago when I jumped to crankfire....
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 03-11-2004 at 06:12 PM.. |
Double Trouble
I have the Crane on my 70 S also. Use it to trigger a Bosch CDI. I love it. I have not even looked inside my dizzy for a year. One of the best "upgrades " I have installed. You will love yours too I bet.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
So after reading all the posts above, it sounds like a tach adapter is necessary. My tach jumps around a bit at idle and a lot during shifts. So to those that have the tach adapter, what is it, is it a Crane unit?
Joe 1993 C2 |
T-bird & others ...
The felt under the rotor still needs to be lubricated at EVERY oil change!!! The weights and cam still need lubrication ... whether points are there or not ... if you want the advance mechanism to continue to function!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Double Trouble
Good tip. Thanks. Guess I'll look in there this weekend.
I just removed the Crane XR700 from my '75 911 and replaced the original points after experiencing intermittent ignition failure. The car would run fine then cut off for a moment, backfire and then run fine. Occasionally it would come to a complete stop and restart after a few minutes. After replacing cracked wiring, Bosch CDI and coil to no avail, I replaced the Crane unit. Problem solved.
Having said this I have the same units on a 75 VW Bus (over 10 years) and a 74 BMW 2002 (5 years) with no problem. No tach adaptor was needed for any of these cars. |
