A/C Evacuation ?
I'm in the process of resurrecting my A/C. I'm trying to verify the system is leak free prior to charging it. I evacuated the system to 24 in-Hg (it took about 3 minutes) and left the pump on for 10 minutes. After three hours there was no change, still at 24 in-Hg. After 18 hours it had dropped ti 20 in-Hg. Is this a problem?
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 03-11-2004 at 07:42 AM.. |
Yes, you have a leak. What type of pump are you using? Given Tuscon's alitude (2600ft?) I would think you should be able to achieve 26 inches or better. Dropping to 20 inches means you definitely have a leak. Jim
Tucson's altitude is about 2400 ft.
So after 18 hours you'd expect the level to still be at 24 in-Hg. What about the effect of temperature. I evacuated the system at about 3:00 pm on Saturday (temp about 85 deg F) and and reread about 16 hours later 7:00 am Sunday (temp about 40 deg F)
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
The system should hold pressure, or vacuum. If it does not, then you have a leak. Do you have barrier hoses? If not, then that's the place to start.
Don't waste the time (or money) recharging until you track down the source of the problem. Scott
1984 Targa |
Certified Pre-Owned
The place to start is o-rings and checking fitting crimps...don't throw money at barrier hoses until the easy stuff is ruled out.
-BG
'84 Carrera Coupe |
1984 Targa |
Certified Pre-Owned
'84 Carrera Coupe |
1984 Targa |
Go to the EPA website and lookup license or certification. |
or.......since your in Tucson, R12 is available in Rocky Point, $8/lb, in 2 kg cans, but of course, your not supposed to bring it across the border.
really try to understand your a/c system before working on it, more is not always better and there is some risk of injury.
Mike B. Gilbert, Az 89 911 Coupe |
I think losing 4 in of vacuum in 18 hours may be a loss due to the hoses on the test equipment. Most shops only test for vacuum for a few (no more than 3 hours) Test again for three hours. If it leaks down in three hours, get some soapy water put it on the connections to the compressor and any other fittings you may have disturbed.
I converted to R134 without much of a problem. Email for details. Mike |
Soapy water on a fitting works only with pressure in the system to blow bubbles. With the system under a vacuum, a leaky fitting might draw the soap into your system -- not a desirable result.
I'm so sorry. You're right. I had such a large leak that I pressured the system with plain air. You can change the fittings to R-134 if you have a small leak and use R-134 to detect a leak.
Who is John Galt?
I'm going to diverge from the rest and say that you may not have a leak. If there was significant moisture in your AC, like if it sat open to the air or was just empty for several years, there may have been considerable moisture. The evaporation of water under vacuum is a thermodynamically governed process and can take a while. i.e., your vacuum started out high but decreased slowly as liquid or adsorbed water became water vapor inside your hoses. Whenever I work on an automotive AC, I leave the pump on for at least an hour. Did you change your receiver/dryer before you pumped it?
What kind of pump are you using?
'79 911sc Targa '02 slk230 kompressor '84 Tamiya Falcon A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years. |
Evacuating the system lowers the boiling point of water which cause it to turn into a gas state and allows it to be removed from the system. Never pressurize a system to look for leaks. Recharge with a small amount of refrigerant and use either an electronic snooper or add dye to the system to check with a black light. Regards |
Like Rondinone asked, did you replce your receiver/dryer? An almost 20 year old receiver/dryer is probably no good and will impede the efficientcy of your system. Also, did you replace the expansion valve? They are fairly cheap ( $25 from Hancock Industries ) and better to place it now than later and have to do the evac/recharge again.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
