Why would my cruise control not work, sometimes?
I never know if my cruise control is going to work. I can predict my wife better than my cruise control. That's not good. What should I check?
Old 03-12-2004, 04:36 AM
3.2 CAB's Avatar
Check all the electrical connections and electrical items, switch, fuses relays, plugs, etc. Most other problems are mechanical, servo bad, cable, linkage, etc. A lot of times, either it works or does not work at all. Make sure everything is tight and clean.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-12-2004, 05:14 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I had issues with mine and it was a vacuum hose that came disconnected on the back of the servo that controls the throttle - cam disconnected when I was tightening my rear struts. The hose is in the engine compartment, forward left hand side - near where the deck strut connects.
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 03-12-2004, 05:20 AM
Thanks, I will check these things.
Old 03-12-2004, 05:23 AM
I had a problem with the brake light switch adjustment. The switch was adjusted to close and it would shut off the cruise. Good luck
Dallas
Dallas
89 911 Cab (sold)
2016 Cayman GTS
Old 03-12-2004, 05:37 AM
Heck, I’m only 5 not 71!
targa80's Avatar
The servo located in the back left side of the engine compartment has two hoses one is fat and one is thin. The thin one is the vacuum line that goes to a connection on the back of the engine fuel injection manifold. The fat hose goes to no where, it just lays in the back of the engine compartment and provides ambient air pressure. My cruise worked fine until the small hose was disconnected. It wasn't intermittent it just stoped working.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 03-12-2004, 06:25 AM
