Question External oil cooler cleaning
While going through the wash, polish, wax routine today, I noticed my external oil cooler is a mess. I need to clean it but am not sure the best way to go about it. Is soapy water and a high pressure washer the way to go or would I be better off spraying it with a degreaser. The horns, while disconected, are still behind the cooler. Since the PO connected a toy horn in the truck that I'm embarrassed to ever use, I'm trying to be carefull not to ruin the originals. I figure someone else has done this before so any input would be appreciated.
S.A.Y.D.
77 911S Targa
Old 03-13-2004, 02:43 PM
vash's Avatar
oily junk all over it? mine isnt oily. i get road debris on it but i hit it with my ghetto sponge reserved for that purpose. connect those horns, i love the beepbeep of the 911 horns!
cliff
poof! gone
Old 03-13-2004, 03:13 PM
Grady Clay's Avatar
SAYD,
Remove everything around the cooler. Horns, rock shield, turn signal assembly, bumper end piece, etc.
Get some Stoddard Solvent (mineral spirits will do) and a big bag of floor dry (kitty litter). Get the oil warm and then hose down the oily parts cooler with solvent. A garden sprayer works well. Use a stiff brush. Repeat over several hours. Finally take the 911 to a high pressure car wash and clean the best you can.
Repeat as necessary.
What type cooler do you have?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-13-2004, 03:23 PM
Chuck Moreland's Avatar
Also, fix those leaks. You are probably leaking at the hose/cooler union.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-13-2004, 03:44 PM
Administrator
Jack Olsen's Avatar
Is it leaking?
Old 03-13-2004, 03:50 PM
No leaks yet but I just switched to Mobil 1 this morning so lets give it some time before I commit. The bottom 2/3 of the cooler is just covered in a dry brown dust but the top 1/3 is covered in a black potting soil type mixture. I'm assuming it's just an accumulation of road sludge but it's worked it's way into the fins. I can't say what type of cooler it is but it looks like the Lemke Design.
S.A.Y.D.
77 911S Targa
Old 03-13-2004, 05:18 PM
