Some more lessons learned: - The heat gun is a fantastic tool, though totally indifferent. It will heat your undercoating equally well as it heats your hand, your pants leg, or anything else you happen to be foolish enough to place in front of it. - Sitting on the concrete floor of your garage gets really old. Padding makes a lot more sense after just a little while. - If you tell your room-mate "As soon as I pull this one bolt, I'll be up for dinner," that "one bolt" will be guaranteed to take 10 times as long as any other bolt. Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
Also the gloves protect from heat and chemicals. I once had almost a half quart of hot oil run out of a filter in a very hard to reach position, after I removed the filter and realized that pain was kicking in, I took off the gloves and my hands were completely red, Lord knows what would have happened had I not worn the gloves... |
wow, this sounds like hard work.
i'm picturing everyone on the board running out to their cars to rip off the fenders to check for rust......... good luck
Rich ![]() '86 coupe "there you are" |
There's really no way to know whether or not it's rusty. I mean, a Seattle-area car is more likely to rust than most other places, and an '80 is more likely to be rusty than an '89. I know that I found surface rust under my fenders, and was pretty happy to have found it before it got bad.
Dan
Registered abUser
Hope I never get this bored and please don't tear the walls off your house looking for termites.
Heck, I’m only 5 not 71!
Yes ripping off the fenders might seem a little extreme to some but if you care about your 20+ year old car and live in a non dry climate it may not seem so extreme. I have seen pictures on this board of rust damage on a late 80's model car from Scotland with some major rust damage.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
I'm right there with ya, Pat -- my next big project is ripping out the backseat to look for rust. Extreme? Maybe. But an ounce of prevention is worth a pound of cure.
Dan
Tearing out the interior was pretty easy compared to what you've been describing. I had a bad leak from my rear window I had to investigate. Luckily no rust was found. Of course, I wasn't worried about reinstalling the big rubber insulation bit (or rather, bits after I was done). I don't know what they used to glue it down, but for a while I thought it was actually bolted in or something crazy like that. On my car there were two short strips of glue at the very back under the rear window that were literally impossible to pull up. I wound up tearing the rubber out and scraping the remaining rubber off with a screwdriver. A stiff putty knive would have come in handy.
![]() Good luck with your fenders! Dan
'78 SC "foxy brown" '69 Datsun "qt" '91 Civic SI "the stereo" |
