Engine # Help
GUY SAYS ITS A 71E BUT # DOESNT MAKE SENSE?
6201001
911/01
911-101-102-2R
IS THIS A 70 E OR A 71?
Old 03-15-2004, 02:35 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Looks like a 70E to me.. 71's had a 3R case ( the 901 #) and had engine serial #'s starting with 620, this one being the one thousand and first produced.
(the engine serial was looked up from the Johnson book, engine code from BA and the 3R being from my pesonal experience.)
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-15-2004, 02:40 PM
OK NEXT ISSUE PLASTIC STACKS MFI ON A 70?
Old 03-15-2004, 02:51 PM
Tim Walsh's Avatar
Possible but not likley. They're a 72/73 only item.
Tim
1973 911T
2005 VW GTI
Old 03-15-2004, 02:55 PM
NO REALLY THEY ARE THERE PLASTIC AS CAN BE . I RECIEVED MOTOR TODAY AND AM CHECKING THROUGH THE #'S
Old 03-15-2004, 04:19 PM
Tim Walsh's Avatar
Intersting but stranger things have happened.. I wonder if someone's rebuilt the motor to 2.4 E specs.
Tim
1973 911T
2005 VW GTI
Old 03-15-2004, 04:20 PM
WELL PUMP # MATCHES 0408-126-010 70/71 E BUT WHO KNOWS MOTOR SPINS FREE AND UNDER THE COVERS LOOK GOOD. HOW CAN WE TELL IF IT IS 2.4 SPEC REBUILD . THIS WAS FROM A FAILED 914 6 CONVERSION SO I FELT A LITTLE MORE COMFY BUYING IT USED AS WORST CASE I COULD PART IT OUT . BUT ALL IS HERE AND LOOKS GOOD .
Old 03-15-2004, 04:37 PM
pwd72s's Avatar
WHY ARE YOU SHOUTING?????
Old 03-15-2004, 09:16 PM
Sorry did not realise caps lock on
Old 03-15-2004, 09:31 PM
found something new and interestin casting # on left side 901-101-3r and on right casting #901-101-102-2r? would this mean it has been split or gone through or could it be built that way original ???
Old 03-16-2004, 08:17 PM
is it possible to have two different casting numbers on same case one on each half ? or was this someone with a bad case using two spare halves put together?
Old 03-17-2004, 03:08 PM
