spring plates
Anybody know of a good source for adj. spring plates............I need a pair.
Old 03-23-2004, 10:14 AM
126coupe's Avatar
smartracingproducts.com
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-23-2004, 11:18 AM
Irrationally exuberant
ChrisBennet's Avatar
You don't mention what year your car is but....
Pelican has the Weltmiester style Adjustable Spring Plates Part # PEL-AS-900 or PEL-AS-910.
Of course if you have an SC or Carrera you already have adjustable spring plates...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-23-2004, 11:28 AM
Thanks Minkoff and Chris.....................its an 87 cab.
Old 03-23-2004, 11:34 AM
CHILI's Avatar
Then it should have adjustable spring plates stock. The only advantage of changing would be if you need more adjustablility? But, if it's a cab, I don't think you're racing it, so I wouldn't think you need more adjustability.
Or are you just replacing them because they are missing?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 03-23-2004, 11:50 AM
Chili,
It does, however I just put on 7's and 9's (fuchs) and the wheel well gaps are pretty bad. We did adjust it down as low is it goes with the stock spring plates but it still ........to me sat to high. My mechanic called me and told me to get a set to do it right.
Any thoughts.
Old 03-23-2004, 11:56 AM
Binge User
Schrup's Avatar
Sounds like your mechanic doesn't want to or doesn't know how to reindex the stock spring plates.
Paul
Old 03-23-2004, 12:00 PM
CHILI's Avatar
Chili,
Any thoughts.
Huh? You don't need a new set, you just need to re-index the T-bars. First put the springplates back into the middle of their settings so you have room to adjust in both directions. If you get a new pair, you would have to do this anyway. I think either your mechanic is smokin crack or you two got your wires crossed. If you do a search you will find tons of info on springplates. Some of it's from me. Most will be from Chuck and the others that do it all of the time. I recently put adjustables (stock like the ones you have) on my car because they didn't have them in '74. They also are needed if you want to corner ballance (which we will all recomend).
Chad aka "Chili"
CHILI's Avatar
Ahh, Schrup beat me to it, but I still say he must because if he put a different set on he still would have to???
Chad aka "Chili"
Old 03-23-2004, 12:02 PM
I'll do some research!!
Old 03-23-2004, 12:05 PM
Binge User
Schrup's Avatar
You will find no greater tool than this for what you need to do. If need be, show it to your mechanic, if his pride will take it. Many guys on this board, myself included owe Wil Ferch a barley pop for creating this.
http://www.vintagebus.com/cgi-bin/spring.cgi
Paul
Old 03-23-2004, 12:13 PM
You can corner balance fine with the factory adjustable spring plate. It just takes a little longer.
While we are on the subject of corner balancing, you really should have to have the car corner balanced after moving the spring plates. "Normal" cars don't have this problem because the rear suspension isn't adjustable. Having the ride height perfectly level has zero relevance to corner weights. To demonstrate this, take a kitchen chair, put two books (same thickness) under two of the legs legs (LF, RR). The chair can be perfectly level yet two of the legs are not even touching the ground.
-Chris
Old 03-23-2004, 12:26 PM
Chris,
they are definately going to corner balance it.
It's also having a Dansk single in dual out installed as well as a few other minor issues.
Thanks all for the quick reponses...it's much appreciated!!
Old 03-23-2004, 12:30 PM
Noel's Avatar
I ended up going with the Sway-Away Plates (They make the Weltmeister Plates) for exactly the reason of easy of adjustability. Sure They cost $300 ($325 for the 87-89), but it was truly amazing how easy it was to adjust the ride height. Well worth my time!!!
See my Rennlist Post for more info.
Noel
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 03-23-2004, 12:34 PM
