welding on 944T caliper question
I am going to have to weld the mounting holes to convert the rear calipers from the 944t calipers to my 76'.
Won't the heat that is put into the calipers ruin the seal's? or will they stand the heat from welding? should I put plug's and weld them in or should I fill them w/weld? I am doing the same set up that Bill V. has on the rear of his car. Thanks OScar |
What's the caliper made of?
Warren & Ron, may you rest in Peace. |
I'm pretty sure it's aluminum.
More Likeable IRL
why mess with it? rebuild the caliper after the weld and not worry about the seal integrity.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Check out the bottom video http://www.alumaloy.net/
But, can it be done w/o damging the seals? and, how.
Seals will probably be fine but I'd go along with k911sc's advice.
Stahlwerks.com
Think about how hot the calipers gets during use and the fact its aluminum. It will disapate the heat very fast.
But, it would never hurt to replace the seals while you have the caliper out, they will be like new.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
More Likeable IRL
so its unanimous, rebuilt and we all sleep better...
I would rather be driving
why not disassemble prior to welding. then you can blast them and make them clean and pretty for the TIG events.
finish off with a nice powder coat or high temp paint.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The filler should be an aluminum alloy that retains its strength when hot and should be a light interference fit as it becomes a structural member. Tig weld both sides
My experience welding aluminum is that you'll ruin the seals for sure. Aluminum make dissapate heat faster than other metals but it also conducts it faster and requirement more heat to weld than steel. Also filling holes on aluminum can be difficult, I'd recommend a filler piece with chamfered edges. Don't forget cleanliness is the key to good aluminum welds so use a SS brush to clean the metal real good. Have you heard of the penny trick for the tungsten?
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
You do not have permissi
I dunno if these are already made(band around a circle of expandable masses), but a circular steel plug put in the piston hole, while welding, could keep the shape of the bore and lessen the need for a total rebuild.
Sorry, more info would be good. You have an early 911(?) with steel(M) or aluminum(L?) 3" caliper-mounting spacing(?), and the non-magnetic 944 calipers to put on are 3 1/5" or more (?). The quality of the weld and material will contribute to the ability to maintain stability, control vibration, and heat for track-only racing. Brakes are no joke. Search for a viper video .mpg here who should have slowed and turned about 90+mph ago.
Meanwhile other things are still happening. |
If that means "what he said"
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Ok, I'll have to rebuild them. Bill, are you saying to use a aluminum plug?, chamfer it and fill the chamfer? Or should I just fill the holes? Which is better?
I have two guys at the shop that weld aluminum very well so the welding will be simple either way. Thanks Oscar |
Oscar,
FWIW, I'd recommend fabricating a chamfered plug, then size it for an interference fit and install it flush. You'll require less filler material and the caliper will be exposed to less welding heat as a result. I might try something like using an aquarium pump or windshield washer pump to circulate water through the caliper during the weld. Remove the cross-over tube (you have one yes?) for more coolant volume. Hope this technique doesn't turn the caliper into a steam powered rocket. Sherwood http://members.rennlist.org/911pcars |
Platinum Member
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
