Tach Bounce Between Shifts
When I shift up or down, the tach tends to bounce up 500 to 1k rpm higher than it should, and then immediately settle to the correct rpm.
Any idea what causes that and how I can fix it?
Sent from my SM-N920V using Tapatalk
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car
1985 911 Carrera Coupe-Grand Prix White/Red
Old 09-21-2016, 06:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If the 3.2, obtain ohm readings on the Speed and Reference Sensors.
'85 Carrera Targa
PCA/POC
Old 09-21-2016, 09:24 PM
Yeah, it's the 3.2 liter. Sorry I forgot to post that.
So this isn't normal?
Odd the way it only jumps up when you're shifting. Within a half second of engaging a gear, up or down, it holds a steady reading.
Old 09-22-2016, 04:20 AM
Uncle Enzo's Avatar
My 2.7 does the same thing. Ive tried to track down the cause but have not had any luck. I guess I have just gotten used to it.
1976 911S
MidYear Fever is alive and well.
Old 09-22-2016, 05:20 AM
Still freaking me out... When you downshift it looks like you're going to zing it the way the needle swings lol.
Old 09-22-2016, 05:38 AM
tshebib's Avatar
I had the same issue when I had my 3.0l in the car. I ended up sending it to North Hollywood to be rebuilt. They told me there are damping springs that stop the needle from "bouncing around". They fixed it but then the tach seems to be sluggish as if the engine is spinning up faster than the tach. That was 6 years ago and now I don't notice the sluggishness so I think it was just in my head.
Old 09-22-2016, 05:51 AM
My tach has already been to them to be resealed. Sigh... Would have thought they would have addressed this.
Old 09-22-2016, 05:58 AM
DRACO A5OG's Avatar
Unfortunately NOHO SPEEDO, will only do work as requested. I had an issue with my speedo, it was clocking too slow, but luckily they warranted it but when the odo failed they charged me for it. WTD?
Is not a refurb a whole refurb?
'85 Carrera Targa
PCA/POC
Old 09-22-2016, 07:21 AM
And I thought my clutch was slipping!!
Old 09-22-2016, 08:34 AM
Registered Minimalist
75 911s's Avatar
mine does it too, join the club. Just some of the patina of our worn out damping springs.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-22-2016, 08:44 AM
In the club of those glad to know what is behind this. My SC's tach does this and at first I thought my clutch was slipping, but it was obvious from the feel and performance of the clutch that it wasn't. But I didn't know what the hell was behind it.
'80 SC Targa
Avondale, Chicago, IL
Old 09-22-2016, 09:13 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Can anyone confirm these springs exist with a pic or two? I've been told it's a thick oil that "dampens" the movement.
Old 11-25-2022, 06:28 PM
lateapex911's Avatar
The guys at Nichols in NC are super fast, and reasonable, and can answer the question(s) on the phone, but it sounds like it needs to go in for a service.
Nichols Speedometer & Instruments - Speedometers, Tachographs, Service and Repair North Carolina
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 11-25-2022, 08:36 PM
kevbo's Avatar
I put up with a jumpy tach for about 2 years. It would also jump on bumps (sometimes), spike to 9k then to 0 after turning on the headlights. I finally brought it in and they said it was the headlight switch 940$. Instead I found another tach for my 86 and now everything works. I just need to send my original tach off to get fixed.
Buy another one and see what happens.
Good luck!
Kevin
1986 Carrera Targa
Old 11-26-2022, 06:23 PM
There are no damping springs in any of the tachs. There are recoil springs to bring the needle back to it's resting position but don't do anything to smooth the needle movement. As the years went on the tach design improved and the bouncing is the most noticeable improvement. I believe it was improved by increasing the strength of the permanent and electro magnets that make up the movement.
The only thing that dampens these tachs is a few drops of a thick oil in the plastic "bushing" that supports the bottom of the needle shaft. If the oil isn't there the needle bounces more and if the oil gets thick and sticky the needle gets sluggish. I've played around with the oil and it doesn't make a lot of difference. I've opened up a couple of tachs that were previously at other shops for the same issue and in most cases wasn't able to improve them. I'm starting to think that the permanent magnet may lose strength over time. It's on my list to do more testing but just haven't had the time yet.
I can post pictures if anyone is interested.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 11-26-2022, 08:14 PM
