LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Try not, Do or Do not
Henry Schmidt's Avatar
Stoney, It's only gas and I have room, if you have a sleeping bag.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-13-2004, 05:00 PM
Send a message via AIM to fintstone
Thanks! It is tempting my friend! Shoot me an email when you set a date..who knows? But I am getting ready to make a fairly long trip to the east coast...so probably a conflict.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-13-2004, 05:14 PM
I'm not here.
K. Roman's Avatar
Is there a website for this?
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 05-13-2004, 05:24 PM
drag racing the short bus
dd74's Avatar
Hey Henry: if you're out and about on the board, I have a question. Remember when you installed my 3.0 you hooked up the old 2.7's hand throttle to give a sort of "choke" action when warming up? The choke action choked and became disconnected. I'm too lazy to try and connect it right now, but was wondering where it could have disconnected and how hard it would be to put it back together.
In the meantime, is it okay to just start the 3.0 and let it idle a little (2-3 minutes) so that it won't stall when I press the clutch in?
Thanks.
Stoney: I'm speechless! You need mirrors on your garage floor. Now if Henry only knew how to cut hair and tailor a suit...
The Terror of Tiny Town
Old 05-13-2004, 05:33 PM
Hi David
The hand throttle has a plastic piece right next to the throttle handle that wraps around the throttle linkage. This plastic piece is notorious for breaking. They cost less than $20.00 and only available at the dealer.
Part # 901 424 317 00 ? from memory.
Good luck
Henry Schmidt
Ph: 760-728-3062
Old 05-13-2004, 05:49 PM
K.Roman
Website for what?
If you mean for the test day, not yet. But when we get close, we'll post it at supertecperformance.com
Henry Schmidt
Ph: 760-728-3062
Old 05-13-2004, 06:17 PM
Author of "101 Projects"
Wayne 962's Avatar
Good call on the part number, however, this part is indeed in our catalog (along with a whole bunch of other stuff):
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=90142431700+&x=8&y=8
-Wayne
Old 05-13-2004, 06:23 PM
Good to know. Thanks Wayne
Henry Schmidt
Ph: 760-728-3062
Old 05-13-2004, 07:05 PM
}{arlequin's Avatar
fintstone,
that is one clean underside! Not only is it bone dry, but the hardware is positively gleaming! Good looking nether regions!
dave
1973,5
Old 05-13-2004, 07:08 PM
Send a message via AIM to 82SC
hey henry can you give a detailed spec sheet/build sheet of your 3.0 MFI...that has always been an engine I've wanted to make
MJ
Old 05-13-2004, 07:11 PM
3.0 case, 95mm Cosworth pistons(10.5 to 1), Mahle cyl., shuffle pin case, twin plug SC heads, 40 mm intake ports, 38 mm exhaust, 930 oil pump, RSR sprint cams, slightly retarded (.5), 2.2 911 MFI pump (stock) modified linkage arm, 40mm butterfly housings, power pulley, 225 fan, 55 amp alternator, Kennedy 228 flywheel and clutch, 1 5/8 headers, megaphones. 280+ on street gas.
Henry Schmidt
Ph: 760-728-3062
Old 05-13-2004, 07:26 PM
dd74's Avatar
MJ
MJ: did you sell your car? From the few photos I saw, it was gorgeous. Sorry about the hard luck.
Old 05-13-2004, 07:32 PM
Originally posted by }{arlequin
fintstone,
Thanks! I wish I could take credit, but that is the way it was when I drove it away from Supertec on 5 Nov '03 after they installed the 3.0. I have not cleaned it since then The 2.7 left an oilslick behind it as you drove the day before. Now if I could only get the body painted. It will do 0-60 under 5 sec with almost 10 year old street tires and a crummy driver. sounds great with the SSIs. It gets better gas mileage than my toyota. I drive it almost every day...relatively hard and have not had to do a thing to it. Not bad for a CIS engine. I can't imagine what that turbo at the top of the page will do in a light car like mine with an additional 100 hp.
Old 05-13-2004, 07:41 PM
dd74's Avatar
Drool cup, please!
Henry: how difficult - and if you don't mind my asking - how much money would it take to duplicate something like that? What's the power range? Torque comes in when? 280 hp at "what RPM?"
Thanks!
Old 05-13-2004, 07:48 PM
Small port, small diameter headers
12k + or - with JE pistons. Add 2500 for twin plug. Max 237 fb @5200 283 @ 7600
Henry Schmidt
Ph: 760-728-3062
Old 05-13-2004, 07:56 PM
dd74's Avatar
Sweet!
Old 05-13-2004, 08:29 PM
yup thanks...TRE is gonna buy it...
don't worry I've got that even more geogeous orange targa with soft rear kit and incredible houndstooth sport seats (TTweed sold me an amazing set)...that is the one I want a trick 3.0L MFI
I have a set of 930 calipers I want to hide under a custom set of welded steel rims with old school hub cap covers...tricked out sleeper
but thanks for the kind words
MJ
Old 05-13-2004, 09:04 PM
