warpspd's Avatar
Send a message via ICQ to warpspd
Tensioner question
I have the original mechanical tensioners in my 76 carrera and I
was going to update to the newer pressure fed tensioners and replace ramps and chain. I came across a set of billet aluminum tensioners. Anyone ever had experience with them? I assume you just set the tension then tighten the lock nut and your set. How often do you have to adjust. The cost savings is quite a bit. Should I go for the pressure fed version or the billet and save
a little $$
Old 04-04-2004, 11:04 PM
big info in "search"
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-05-2004, 07:31 AM
Gon fix it with me hammer
svandamme's Avatar
i had em in mine, they're supposed to be a bit tricky to set the tension, as over tension will strech the chains> not good
they also need periodical checking, every xthousand kilometers
mine was already slack when i upgraded to pressure fed ones.. imho i'de go with pressure fed, peace of mind for a small price
Stijn Vandamme
BIMDIESELBMW116D2019
Old 04-05-2004, 07:52 AM
