Altenator / Voltage Regulator
I have a 1980 Weissach that I think needs a voltage regulator. Where is it, how hard is it to change out and how do I tell which model I have so that I can order the part in advance of removing the old one?
www.freewebs.com/godsgood 1999 VW New Beetle 1985 VW Vanagon Westfalia 1983 944 - Parting out 1980 911 - Weissach Edition |
why do you think it needs a new VR?
poof! gone |
When idling in the drive way if you depress the accellerator the lights get brighter.
Re: Altenator / Voltage Regulator
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
poof! gone |
Buy a multitester...see what your output is...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
why don't you have a volt gauge by now ? anyway a volt meter on the battery at 2k rpm with lights and heater blower on will tell the tale
at two-k with lights and blower on, i am kicking A at 14+ volts. i always wanted one of those voltmeters that you can plug into the cig lighter. never did find one. i tried to make one with my multimeter and an old cig lighter plug, but my electrical ignorance reared it's ugly head and i failed miserably.
poof! gone |
cig lighter plug in voltmeter can be bought from Nordskog Performance, 1120 Yarnell PLace, Oxnard, CA 93003. PHone is 805-483-2411. Part number is M9025. Forget exactly what mine cost by the time it got here...around $60? It's digital, but one feature I like is it's memory button...to recall the highest voltage reading, you press a button on the face. Nice for checking, since when driving I don't want to watch the V meter all the time...
thanks pwd72s. i will try not to crash my car staring at the meter. haha.
poof! gone |
I thought my regulator was going out ('74 911s). It was charging upwards of 20 volts at 4000rpms... turns out the battery cover was loose and everything worked out after I topped it off with some distilled water.
Best, Ian
'74 with webers... Ferdinand Porsche's concerto in flat-six major... |
Some great ideas here, especially for the testing to avoid replacing a working part. However, if I do find that I need to replace it I don't want to take the vehicle out of service to wait on the part. Is there a way to tell what voltage regulator I have without taking the existing one out? Where is it located?
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
There are previous threads with pictures of the external voltage regulator.
This thread has a picture I posted of the engine bay wiring. The external voltage regulator is the one with the yellow label on it. I just looked at the post the first picture has a box with a yellow label also but that is not it. Look at the pic I posted in the thread. Engine Electrical Question
Pat Henry Targa80 1980SC Targa (Mocha Brown) Last edited by targa80; 04-05-2004 at 01:21 PM.. |
pat henry, i was trying to emphasize my electrical skills. or lack of. i was sorta joking. i didnt want to bastardize my stinger flashlight car charger. and my other salvage piece had a break internally. i gave up from there.
poof! gone |
Thanks the picture helps greatly. I don't mind unplugging something to look at it a put it right back, but I didn't want to pull the altenator or something and have the car down while I was awaiting parts.
I have a voltage regulator external type. I'll send you a pic if you want it. $10 sound fair? I had to rebuild my alt and found out it har the reg. in the alt.
"I don't want to watch the V meter all the time..."
- How about hooking up a storage O'scope? Ya wanna have fun or what? |
http://store.yahoo.com/rodi/vec008.html
This <$14.00 meter came recommended by several Pelicanites. (Sorry...I couldn't find the actual posts.) I bought one over a year ago and use it for every day monitoring or spot-check metering. It's inexpensive, but I find that the readings are VERY close to those from my Fluke multimeter that I paid nearly $150 for. I normally don't keep mine in the cig. lighter because it blocks access to the CD tray of my audio head, but I take the meter out of the glove box and plug it in anytime I suspect that something's amiss. Last week I sensed that my car wasn't starting as easily as it should, so I stuck the meter in and left it there for a couple of days. It didn't take long to see that my alternator was charging okay but the battery wasn't keeping a full charge. Sears replaced that battery today today (free) under warranty.
Here's a (bad) pic of the meter in situ:
