Power to windows problem
My power windows are not working. After searching the threads here and trying all I can think of, I need some electrical help.
I have used a probe and determined that power is not getting to any of the switches. I have replaced the fuse and swaped out the window relay.
At the fuse block, I grounded the probe and checked both sides of the fuse block for the window, it has power.
If the fuse gets and passes power and it's not a relay, where is the fault?
Can anyone help me with a valid test to find the short at the fuse block / relay area?
Old 04-07-2004, 02:33 PM
bump
I like them I drive them
Old 04-07-2004, 10:48 PM
doozer's Avatar
Do you have power at the drivers side controll for the drivers side window? ( at the switch terminals)
Have you checked the multi-pin connector on the drivers side door ( what you would unplug if you were removing your door ) it is behind the panel in the floorboard.
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 04-07-2004, 10:57 PM
Heck, I’m only 5 not 71!
targa80's Avatar
What year and model car?
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-08-2004, 08:04 AM
actually, that multi-pin connector is in the upper part of the door jamb, just below where the fender swoops back beside the windshield. they get unplugged sometimes.
206 637 4071
Old 04-08-2004, 08:06 AM
its a 77,
I will check the multi pin connector.
Old 04-08-2004, 09:36 AM
doozer's Avatar
Yea Jonny you are correct I meant to say while laying in the floorboard
Todd
Old 04-08-2004, 09:41 AM
