				cis hell
			I just had the same problem on my 82 sc. replacing the fuel distributor fixed it.
				We had one other indication, when the ignition was switched off fuel pressure @ the distributor dropped to 0 within a few seconds even after changing the accumulator
	82 911sc Targa  |
 My mechanic found the problem, replaced the boot and reset the mixture and I have to say the car has been running like never before, cold or warm... Bye -J
	We're all in the gutter,but some of us are looking at the stars. -Oscar Wilde  |
				Thank You Tom
			I too thought I was in CIS hell, and had been reading up on where to begin.  I've checked for vacuum leaks, adjusted the idle, etc.
			After changing the fuse - no irregular idle. Who would have though it was that simple. Tom - thanks for the heads-up. Dustin
	Dustin Johnstone 82 911 SC 93 Mazda RX-7 97 Land Rover Discovery  |
			Should we CIS people just plan on changing to EFI via Tony's EFI conversion... or should we expect these kind of hair pulling episode with that setup also?
	77 911, 3.0L  |
				UPDATE  Problem Solved
			I finally solved the problem.
			The ultimate cause of the problem: O-ring on the fuel pressure valve in the fuel distributor had split - it split into two seperate O-rings and letting fuel pass between the two halves. Thanks again for all the input. AFJuvat
	Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information  |
			It will be interesting to see how reliable the EFI systems are after they've cooked in an engine compartment for 30 years and if one can get EFI repair parts in the year 2034.
	  Jim
	poof! gone  |
			Just to shed some light on some of those that may be wondering why did changing a fuse that controls the dome light fixed "DustinJ's" issue, the dome light fuse is a sign that power is getting to the oxygen sensor relay which powers the ecu (both of these under the passenger seat) in which the ecu passes its workload to the frequency valve and the frequency valve helps with the A/F ratio on the Fuel Distributor.
	~Al 1974 911 3.0 1971 911T 2.2 Truck & Motorcycle  |
			i had the same prob took off one of the hoses. some dumb ass put a plug inside it  the plug got loose and made idle change
			My $.02
					Fuel injectors, bad ignition coil, and the distributor is not advancing. Swapping the coil is an easy test. The others require some cleanup and testing. I would also suggest using the O2 sensor and CIS brain again, it is powered by the dome light circuit. Better gas mileage and the CIS does run better when the loop is complete. Good luck.
	If it has a skirt or tires, it WILL cost you money!  |
