Location: member Central PA Region PCA , Home of the Hershey Swap
Help w/84 Carrera 3.2 O sensor connections
'84 Carrera 3.2, the new O2 sensor has 2 identical white wires and a black wire. The black clearly goes to the DME pin 24 green wire via a separate connector. A brown ground wire originates from DME pin 23. And the yellow heater wire arrives vis the pump relay. Green and blck clearly connect. But how do I tell which White wire is ground and which is heater, or doesn't it make a difference. I tried an ohmmeter to each white wire pin, then to the O2 sensor at the body of the sensor and it's exhaust connections without any success. Perhaps it does'nt make any difference, but please help.
Old 04-09-2004, 09:37 PM
Friend of Warren
doesn't make any difference
Kurt V
Old 04-09-2004, 09:42 PM
Thank you so much Kurt.
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 04-09-2004, 09:48 PM
