About to change tires...
I looked under my car to help the tire tech at a local tire shop, and we identified 4 jackplates at each corner of the car. Just inside of the rocker panels in the front and a little further in for the rear.
I figured these are the factory jackpoints for a hydrolic lift. I know it's not as straight forward as my Accord, but are these the spots the shop would use to raise the car for a tire change?
Phattey...
'87 911
'95 4Runner
'05 Screamin Eagle ElectraGlide
Old 04-10-2004, 05:28 AM
Bill Verburg's Avatar
Yup, be sure to use a block of wood or hockey puck between the lift pads and the body.
this shot sort of shows how it will sit
Bill Verburg
Old 04-10-2004, 06:05 AM
If You have an owners manual there is a diagram in it that shows the lift points.
Old 04-10-2004, 07:54 AM
Thanks....I was being a little too carefull....if there's such a thing.
All is good...and I have a new set of Michelin Pilot AS's.
Phattey...
'87 911
'95 4Runner
Old 04-10-2004, 02:54 PM
