rob justice's Avatar
Twin outlet silencers - body mods????
My car (85 Carrera) is finally in the paintshop, does any one know what modifications are required to the rear valance and quarter panels to allow fitting od a Dansk 2in 2 out silencer. I am sure one of the quarter panels (ns/lhs) does not require any mods and its only the (os/rhs) quarter panel and the centre valance (outer edge) needing mods.
If the panels need cutting - I intend not to get them painted until after cutting - the engine is not fitted just now to allow me to trial fit the panels.
Cheers
Old 04-11-2004, 12:43 PM
dickster's Avatar
rob,
i just cut the rear valence on mine.
Rich
'86 coupe
"there you are"
Old 04-11-2004, 12:55 PM
So am I right in saying the the quarter panels require no mods?
Old 04-11-2004, 12:59 PM
dickster's Avatar
thats right. the right and left are slightly different, but you only need cut the valence, unless you want both sides looking "exactly" the same - the difference is very subtle.
Rich
'86 coupe
"there you are"
Old 04-11-2004, 01:41 PM
suberb - thats an other couple of bits paint shop bound!
Old 04-11-2004, 01:45 PM
Glasgow 911SC's Avatar
So that's you almost at the finish line Rob? When do you expect to be on the road?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 04-11-2004, 01:47 PM
I have no idea how long the paintshop will take - it depends purely on how busy they are but I hoping it will take less than 4 weeks.
I am awaiting for the new front valance to arrive from Germany - I only discovered I had the wrong one when it hit me there was no way to connect the front spoiler - no holes! So it should be here by the end of the week. Engine and gearbox should be reunited pretty soon also along with new clutch etc. I would like to have it on the road this summer.
Old 04-11-2004, 01:56 PM
dickster's Avatar
photo (shop) experts help needed
check this out, it shows how the right side qtr is close to the outlet - can you live with that?
Rich
'86 coupe
"there you are"
Old 04-11-2004, 02:01 PM
Pretty tight but it looks ok - any problems with the heat burning paint?
Old 04-11-2004, 02:07 PM
dickster's Avatar
rob,
no, no problems.
Rich
'86 coupe
"there you are"
Old 04-11-2004, 10:52 PM
Dickster - one final question - what size of tailpipes do you have fitted in those pictures - I'm sure the silencer I'm fitting has 3" outlets.
Old 04-12-2004, 03:13 AM
Think he has the 84mm ones if I remember correctly.
Chris
Old 04-12-2004, 04:04 AM
Bill Verburg's Avatar
Here is a pic of the original and cut valances side by side.
Bill Verburg
Old 04-12-2004, 04:19 AM
Cheers for that Bill - thats a fair bit of cutting! I thought it would just be a case of trimming one edge slightly. Understatement or what.
Old 04-12-2004, 04:25 AM
chrisp's Avatar
The two cuts end up being symmetrical relative to the nearest mounting bolt. By this I mean, you can use the location of the stock cut relative to it's nearest valance mounting bolt and transfer that pattern to the right side and position it relative to that valance mounting bolt. This is what I did and it came out perfectly positioned. There is a different shape to the drivers side lower splash guard versus the passenger side. It's not a big deal though and isnt required. With the 80+mm outpipes you may have to mod both sodes. I have the regular Dansk two out sport (not the huge outpipes) and it fits well.
'83 SC
Old 04-12-2004, 06:36 AM
dickster's Avatar
rob, mine are the 84mm i believe.
i will check when i get a chance.
Rich
'86 coupe
"there you are"
Old 04-12-2004, 06:37 AM
jmz jmz is online now
jmz's Avatar
Bill,
Where in the he!! do you get all these educational, informative pictures.
Anytime someone asks about something you've always got a pic, graph or some other illustration to provide.
Cool!
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 04-12-2004, 07:09 AM
Cheers for that lads! I'm going to dig out the grinder tonight and start cutting.
Old 04-12-2004, 09:18 AM
