si2t3m's Avatar
Don,
what kind of intake manifolds are you putting between the carbs and the heads??? Early intakes?
Here is my setup on a 3.0L from a 1978 911 engine (38 or 39mm intake ports).
Weber carbs
Weber Intake manifolds bored out to the side of the intake port on the 3.0L heads.
So from the heads to the carbs it's like this:
Heads-gasket-insulator-gasket-manifold-gasket-carb.
If you are using manifolds made by PMO that are specific for the 3.0L then you might not need the insulator. The weber manifolds when installed on a 3.0L dont cover the intake port properly. Well they do cover it but just by a hair where the half round area is for the injector on the intake port. You will drive aroud for a while and the gasket will get sucked in the intake port in this area creating a vacuum leak.
Why not call/fax PMO and get this straight. He makes insulators and the proper gaskets for this.
Marc-André
Marc-André
Present: 07 997.1 GT3 white, 95 993 coupe Riviera Blue, 72 911E Targa Silver, 68 912 coupe Burgundy, 67 912/911 coupe Black
Past: 98 993 C2S, 98 993 Speedster conversion, 95 993 Cab, 70 914-6 conversion 3.0L Webered
Old 04-16-2004, 12:13 PM
si2t3m's Avatar
One other thing. then insulators are a good thing with carbed engines.
Like preventing the gas from boiling in the bowls...
Marc-André
Marc-André
Old 04-16-2004, 12:16 PM
But the tech guy at Pelican said they are only for early engines.
Old 04-16-2004, 02:06 PM
Does anybody have a phone number for PMO? I don't have a fax machine. Or if you have a fax send one for me asking if intake manifold insulators are needed for converting a 1981 SC 3.0L to Weber 40 IDA 3C carbs. If so tell them I need to order them and my number is 215-356-7971. Thanks!
Old 04-16-2004, 03:57 PM
Randy Webb's Avatar
Can yo send a fax from your computer?
I hear he doesn't like Email or phone...
Old 04-16-2004, 04:06 PM
Hi Don:
PMO doesn't take phone calls and instead, works mostly through his dealers.
One should always use insulator kits for ALL carburetor installations due to the volativity and vapor pressure of today's gasolines. This prevents the float bowls from percolating during heat soak and flooding the engine with fuel.
That results in engine fires and in some cases, bent rods from hydrolocked cylinders.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-16-2004, 06:12 PM
PRO Motorsports
Tyson Schmidt's Avatar
Originally posted by Randy Webb
Tyson how do you set it up or modify it for use in a "recirculatory manner."? What hose runs where to recirc.? What other items do you need besides the pump & hoses - a holding canister?
PMO sells a fixture that has an inlet and return, then there are two outlets from that going to each carb. It has a gauge built in and a restrictor on the return for setting pressure.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-16-2004, 07:34 PM
si2t3m's Avatar
OMG!!!
Wayne.... Time for some serious head slapping
Marc-André
Old 04-17-2004, 05:04 AM
I have finally talked to somebody in person who seems to be an expert, Bob Fox of German Car Service of Ambler, Pa, who has worked on Porsches and BMWs since the early 60s when Wayne was in diapers (my words not his). He says yes insulators or spacers are a good idea, also needed is a regulator with a gauge built in. Finally, he said another problem is clearance with a AC condensor. But since high stacks lead to better performance, I may need to find a filter that takes up very little room.
Don
Old 04-17-2004, 10:41 AM
Randy Webb's Avatar
Tyson -- do you mean their "fuel pressure control unit"?? From the web site description I thought that was for use when you _keep_ the higher pressure CIS fuel pump.
No?
Old 04-17-2004, 03:09 PM
