Randy Webb's Avatar
Large wrench sizes needed
What large size wrenches are needed to work on a 911 -- i.e. larger than 19 mm?
22mm is needed for something or other, right?
there are the nuts on the steering wheel
and on the rear swing plate adjusters - what sizxe there?
what else?
Old 04-16-2004, 10:19 PM
Doug Steinel's Avatar
The steering wheel is held on by a 27mm nut... but you don't /can't use a wrench on it. You need a socket with extension.
77 911, 3.0L
Old 04-17-2004, 05:39 AM
Cool
maybe a full set of Harbor Freight 1/2in rachet, sockets, large wrenches, flex head rachets, etc. is inexpensive enough to get started. Then you'll know what items you'll need to dial in.. like the short Snap-On swivel sockets are a bit unique because they are very short.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-17-2004, 06:23 AM
avi8torny's Avatar
Send a message via AIM to avi8torny
32 and 36 for the oil lines
12' GT3
18’ 991S
Old 04-17-2004, 06:34 AM
Irrationally exuberant
ChrisBennet's Avatar
The trailing arm ride height adjustment requires thin 24 and 36mm wrenches. 22mm also fits the O2 sensor on cars with those.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-17-2004, 06:44 AM
Send a message via AIM to Oldporsche
Cool
I have, when necessary, that the pawn shop sometime has old large wrenches. I take them home to modify with a dremel tool. This gives me the right size at a modest cost.
David Duffield
Old 04-17-2004, 08:51 AM
mm86911's Avatar
22mm for rear lower shock bolts, inner banana arm bolts and front upper strut mounting nuts.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 04-17-2004, 09:17 AM
beepbeep's Avatar
32mm 2/3-inch socket for rear hub.
Thank you for your time,
Old 04-17-2004, 09:37 AM
Randy Webb's Avatar
Thanks folks - but let me clarify this. I am not purchasing wrenches. Instead I have a big Snap-On set of closed end wrenches. I notice that over the years I never use the big ones at all. I am thinking of putting the ones I will never need on eBay and clearing some space in my tool box.
So far, the only normal closed end wrench I see that is needed is the 22 mm one. True? It looks like everything else is either a special wrench (oil lines) or a socket. ...
Old 04-17-2004, 03:52 PM
