H1 Install--Finally--need a little help (Pics Too!)
I'm finally installing these 1 year after purchasing them and getting the chrome redone and figuring out how to put them back together. I just removed the old SC headlight and there were 4 or so little screws that held the old headlight assembly inside the fender hole opening. As I'm looking at this H1 light, I only see one screw that will hold this light in place after I plug in the light assembly--is this correct?!
1980 911SC Targa 3.6L Last edited by JonT; 04-11-2004 at 08:05 PM.. |
One screw at the bottom is correct. The top should seat over a small tab which keeps it in place. The bottom screw is either a finish screw if your just using the chrome ring or a special screw that a finish screw will thread in to if your using the cover rings.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
Here's a coupla pics--I couldn't wait so I just set them in and took a couple. I can't believe there is only one screw that holds these in!
1980 911SC Targa 3.6L |
