LinkBack | Thread Tools | Rate Thread |
Is there anything I can do to clean up the threads on the expose male side?
It is not an alignment issue. I can get it started ok, then it just stops. I want to avoid using a wrench. Could I figure out the size of the thread and run a thread die over it and try and cut/clean new threads??
Any thing else? Thanks, Ian |
Friend of Warren
Exposed threads on what???? Need a bit more information here.
Kurt V No more Porsches, but a revolving number of motorcycles. |
How to clean up/cut new threads on Filter housing male side
I'm having trouble getting a line to screw in by hand. I don't want to use a wrench if fear of the dreaded cross thread.
Can I cut/clean new threads? Anything else to get this to work? thanks, Ian |
Senior Member
We still don't know what you're trying to clean up, but a die can probably be run over those threads to straighten them.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I'll guess it's about the brake lines
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
There's a previous message that references the oil tank - maybe it's oil lines or the filter?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
I think he's talking about the oil filter neck that threads into the filter itself.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
I think the answer is yes - you can simply run a die over the threads to clean them up. I do it all the time.
For really big stuff, they make a tool called a "thread restoring file". Greatest thing in the world for fixing buggered up threads. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
