emarsh's Avatar
CV joint replacement
I noticed that one of my CV joints in in need of replacement. Should they be replaced in pairs?
1979 911 Targa
406ci Chevy powered '88 Fiero GT
Turbocharged 2000 Suzuki Hayabusa
1990 Buick Reatta
Old 04-18-2004, 10:29 AM
AFJuvat's Avatar
Are you replacing just the joint or the whole shaft?
It is not necessary to replace both shafts at the same time. However - you will usually find that is one is about to die, the other isn't far behind.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-18-2004, 11:14 AM
Cymru am Byth
carmad's Avatar
If the driveshaft is off the car I would do them both, as the wear will be similar on both.
This is why I did all mine, but believe it or not this did not make any noise.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 04-18-2004, 04:33 PM
Wow Julian I have never seen that before.
Emarsh, if your time is free, you can just replace the one that's bad and plan to replace the other at some point in the future when it too goes bad. No harm done.
You can also also swap CVs from side to side, so they run the other direction. This allows you to get a lot more life out of them.
Old 04-18-2004, 04:38 PM
Now in 993 land ...
aigel's Avatar
Just put in a couple of new axles. That's most pain free and very affordable through PP. I wouldn't start messing with a single CV joint. If it is gone, others will be close to the same. To me it's like putting a single brake pad on your car.
George
81 SC (sold)
Old 04-20-2004, 12:52 AM
IROC's Avatar
I'm a believer in the "don't fix it if it ain't broke" theory. I would go as far as to clean and repack the CVs, but there is no sense in replacing something that isn't worn out.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-20-2004, 04:54 AM
