"Cheap is expensive"
Re installing brake pads
I went back to install the stock brake pads which are thicker and those pistons are not budging. I don't have that special tool I see in my book to spread them apart so what are my options?
Old 04-22-2004, 08:32 AM
Detached Member
Hugh R's Avatar
Pull the caliper off and use a large wood clamp.
Hugh
Old 04-22-2004, 09:43 AM
disband
juanbenae's Avatar
have you removed the cap on the master cylinder? watch for over flow of the MC when you push them back in.
Old 04-22-2004, 10:01 AM
There must be a better way then to pull the calipers off everytime you want to change the pads. I guess if I got that tool I saw in my book it would work for me.
Old 04-22-2004, 10:12 AM
I have an idea
Old 04-22-2004, 10:20 AM
Friend of Warren
Hell I just take a BF screwdriver and wedge it between the piston and the rotor and just give it a twist. Never had any problems doing it that way.
Kurt V
Old 04-22-2004, 10:22 AM
OZCarrera3's Avatar
Ok, one of you guy's had to put me away! I wan't a pair of 8 or 9 inch wheels! Can sonwobwe accomodate me ?
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 04-22-2004, 10:25 AM
pwd72s's Avatar
Don't use the screwdriver trick! You don't want to scratch the finish on your pistons or damage a seal. Do you still have your old brake pads? If so, put them back in, then use your screwdriver between their compound and the rotor. The plate of the old pads will protect your pistons & seals, and since they are to be replaced, marking up their compound won't matter...
Old 04-22-2004, 10:54 AM
CHILI's Avatar
And with any brake job (not just P-cars) don't push too quickly. That's when you can create problems such as MC overflow and broken seals. Just let the C-clamp or specail tool/BF screwdriver do the work. I.e. don't force it.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 04-22-2004, 10:57 AM
You can also use a really large pair of channel lock pliers between the old pads and the calipers. Just protect the caliper side with a rag or a piece of rubber.
Mike
1986 930
Old 04-22-2004, 12:45 PM
Automotive Monomaniac
Emission's Avatar
I use the brake tool, or a C-clamp - slowly.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-22-2004, 12:47 PM
Thanks, what is the brake tool?
Old 04-22-2004, 01:18 PM
jbripps's Avatar
The tool is actually called a brake pad spreader...it is sold by our host.......looks like an "X" with a twist fly bolt that slowly spreads the ends. Like like a surgical tool.
The C-clamp should work well also.....that's what I use on the other cars.
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 04-22-2004, 01:36 PM
Thanks guys, that is the info I needed. Nothing like experience,
Brent
Old 04-22-2004, 02:36 PM
