Arrow PPI Results-Big Question
Well the PPI came back on my 87 Carrera. Mechanic states:
Compression between 160-180, Leakdown 3-4% on all cylinders BUT ONE!
I didn’t catch the compression on the “bad cylinder,” but leakdown 50-60%. Mechanic says that a piece of carbon may have come off the spark-plug and is preventing the valve from seating completely. He wants to repeat the compression/leakdown tomorrow. Says the car runs strong.
Does this sound right to you???
I am hesitant, but want to know if I should be?? Is it possible that the mechanic can replace the spark plug, run the car a while and the re-test will come back fine???
Thanks,
Alan Stark
Old 04-21-2004, 04:55 PM
Used Up User
imcarthur's Avatar
Alan
I have walked from 2 cars in the last 3 weeks for the same reason. I've read & searched & asked. I would like the answer too, but I suspect it will be fuzzy.
Both mechanics involved suggested that the car just hasn't been run enough & carbon has built up. With a good thrashing, the valve will reseat.
Can it?
Ian
'87 Carrera Cab
Old 04-21-2004, 05:28 PM
pwd72s's Avatar
If possible, I'd suggest running it hard for a while, with a good carbon cleaning additive in the gas, then retest. If that one cylinder remains bad? I'd walk on buying the car. Rebuilds, even just top end ones, aren't cheap...
Old 04-21-2004, 05:34 PM
Friend of Warren
What the mechanic says is possible. Could also be a bad valve adjustment or a burnt valve. I would run the car then retest.
Kurt V
Old 04-21-2004, 05:47 PM
Make Bruins Great Again
Por_sha911's Avatar
Every bad motor "just needs a good tune-up and it will run like new..."
If its not carbon, you just bought an extra $5-10k worth of repairs. How big a gambler are you? Don't let your emotion and desire to have a car cloud good judgement.
IMO: buy a bottle of techtron and ask the owner to drive it till empty and you'll have the test done again -or- walk away.
Joe
Old 04-21-2004, 05:52 PM
Used Up User
imcarthur's Avatar
Just to complicate things, Alan's car & one of mine were 1000 miles away & we're relying on a good mechanic & a PO to do all of this . . .
'87 Carrera Cab
Old 04-21-2004, 06:01 PM
Thanks Guys, So What I'm Hearing:
If the cylinder re-tests OK, then don't worry-be happy and drive the car home.
More than 10% variation in compression and/or more than 5-6% leakdown (other cylinders 2/3%) WALK.
Ian--we've never met, but I feel as though I know you! We have been in the market for a p-car and both have had disapointments. Sounds like you (and I) are willing to walk until the right car/right price comes along.
Thanks for all the input, keep it comin
Alan
Old 04-21-2004, 06:11 PM
Used Up User
imcarthur's Avatar
Good luck, Alan.
I hope it works out - you'd look good in that car & the drive home would be fun. But, walk if you have to . . .
Ian
Oh yeah, and while you're in Florida do you mind having a look at a car for me . . .
'87 Carrera Cab
Old 04-21-2004, 08:03 PM
jyl jyl is online now
jyl's Avatar
Might have the owner pay for a valve adjustment too. I had seemingly bad leakdown numbers on my PPI (15%-ish), the mechanic did a valve adjustment and re-tested, leakdown was much better (<3%-ish).
Old 04-21-2004, 09:43 PM
Send a message via AIM to fintstone
Only buy if discounted enough to pay for the risk unless you get better results on test.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 04-21-2004, 10:14 PM
Senior Member
Jdub's Avatar
Prior to retest, have mech. adjust valves on the bad cylinder only. Drive it hard, then retest. That's the cheapest way to get to the bottom of this.
John
'78 Targa in Minerva Blue
Old 04-22-2004, 08:15 AM
chrisp's Avatar
Step 1: Toss a bottle of Techron in the tank and drive the tank empty (so you get the cleaning benefits of a full bottle of Techron).
Then do the retest.
The valve adjust sounds like a viable option but I would consider that step 2 if step one doesn't work..
'83 SC
Old 04-22-2004, 08:39 AM
Broke
Westy's Avatar
Old Cadillacs (500 CI's) used to build up a lot of carbon, and it would eventually break off. I heard one with this problem and I swore a rod had snapped. Scary but harmless. Threw a can of Carbon Blaster in there and BAM!! it was all gone. I just can't imagine a piece of carbon sitting in the valve seat area. All the air and cycling of the cylinder would (should) pass it through the motor. Hmmmmm JMO
Brian
Beer is proof that God loves us and wants us to be happy. B. Franklin
93 968 Cab
81 SC Targa (Princess) Now Residing in Denmark
1973 RS Z28 Vash will never own it!
Old 04-22-2004, 09:37 AM
teamgomez's Avatar
Tap valve!
Had same with engine out- tapped hissing valve with plastic hammer and the carbon dislodged, valve seated 4.0 and engine fine. I believe best practice is to leave plugs in until you get to that cylinder so any carbon doesn't fall during removal and get a chance to lodge itself in the valve seat. In my case I think it was intake garbage that came off when I removed the intake runners.
2004 GT3
1969 Camaro 502 ZZ BBC
1980 Weissach 911- gone to a good home in Colorado
Old 04-22-2004, 09:55 AM
Broke
Westy's Avatar
I stand corrected. Gee, there's a surprise. I just read an excerpt from Wayne's book, and he clearly discusses the carbon on the valve and how it can flake, then sit in the valve seat causing lack of closure. I think it's in chapter 18. Oh well..............
93 968 Cab
Old 04-22-2004, 03:14 PM
