slater's Avatar
Desperate for Pertronix help
Have a 67 912 with a 75 2.7s engine. I am installing a pertronix ignitior system. The engine is all the way intalled, but I am having problems with the ignition. I know the red wire goes to 12v switched, but where specifically does the black wire go? The info I have found says to go to the same place the point's negative wire went, but since I didn't start out with an enigne in the car, I am not sure where that is on the CDI box (A, B, C or D).
Thanks - Kris
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 04-30-2004, 09:32 PM
Early_S_Man's Avatar
Porsche Crest
Kris,
'D' is the double ground tab on the case of the CDI unit ... right next to the 3-pin connector ... though the engine wiring harness should have a braided ground shield that runs from coil to distributor to the CDI case ground.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-30-2004, 09:41 PM
slater's Avatar
I don't want to sound stupid, but just to make sure you are saying that the negative from the pertronix goes to the D on the cdi box? My engine didnt come with a wiring harness, so I have pretty much done this all through wiring diagrams... it's been a real PITA.
Old 05-01-2004, 12:21 PM
Porsche Crest
Yes, that is correct, though not all factory schematics show a 'D' terminal on the CDI box. Here is a Bosch publication page that doesn't show the ground tab on the case as 'D' though the ground connection is there without a label:
Warren Hall, Jr.
Old 05-01-2004, 03:36 PM
lateapex911's Avatar
Is Warren just the walking (and scanning) encyclopedia or what!?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 05-01-2004, 06:28 PM
slater's Avatar
perfect thats just what I was looking for. thanks a lot
Old 05-03-2004, 05:08 PM
