Why fo the purists not like v8 conversions?
? is it just because it isnt a porsche motor or are there real reasons?
Old 05-01-2004, 01:18 PM
moazam's Avatar
Send a message via AIM to moazam
Search the forums and you'll find the answer.
2014 Porsche Cayman S
2001 BMW 525i Touring
1996 Porsche 911 (Gone to Germany)
'86 911 Carrera (Gone to Aruba)
Old 05-01-2004, 01:21 PM
FenderGuy's Avatar
because the V-8s go faster hee hee
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 05-01-2004, 01:22 PM
thats what i was thinking. i am a CAR fan... if it performs better for less money i think its a good idea. right?
Old 05-01-2004, 01:24 PM
on-ramp's Avatar
Re: Why fo the purists not like v8 conversions?
not having a Porsche motor is not a real reason?
Old 05-01-2004, 01:26 PM
i dont know, you tell me. i should have said "other" reasons
Old 05-01-2004, 01:27 PM
scottb's Avatar
Do you WANT to get flamed?
1984 Targa
im just wondering...
<-------- newb
Old 05-01-2004, 01:30 PM
bigchillcar's Avatar
well...if you have to ask...
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-01-2004, 01:40 PM
BURN-BROS's Avatar
You should talk to the guys in the 914 forum. This conversation won't end up with people on fire and first degree burn over there.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
...riiiiiiihgt
moazam's Avatar
Like I said, use the search.
The weight of the v8 screws up the Porsches weight distribution. You'll probably end up with a fast car that spins out on corners.
For the money you'd be better off with a 3.6 Varioram or something. You'd also be able to actually sell the car one day if you wanted to.
Old 05-01-2004, 01:59 PM
PMAC
Guest
Posts: n/a
Hi,
Have you actually checked out the weight of the "heavy" v-8's. A chevy weighs somewhere around 500 lbs, while a 5.0L Ford weighs about 460 lbs with cast iron heads. Knock 40 to 50 lbs off when the heads are aluminum. Now go to Bill Verburg's chart and check the weight of that 3.6 varioram.
Just trying to help.
Thanks,
Pat
Old 05-01-2004, 02:08 PM
nostatic's Avatar
why do you want a Porsche?
A large part of the vibe of the 911 is the flat 6 engine. It doesn't sound like anything else. Add that into aircooled (assuming '98 or older) and rear engine, along with classic lines and you've got one of the finest and most recognizable cars ever made.
To replace the flat 6 with a bigger flat 6 offends some purists, but is tolerated (and suggested) by a lot here. But to remove the flat 6 "heart" of the car and replace it with anything else...well, then it just isn't the same.
Actually I think some V8s are lighter, so the weight distribution isn't the main reason. The V8 does result in a slightly higher CG though I think...
Old 05-01-2004, 02:09 PM
RETIRED
Joe Bob's Avatar
WATER SUCKS
2012 ML350 3.0 Turbo Diesel
Old 05-01-2004, 02:10 PM
Mark Wilson
Guest
Posts: n/a
Just get a Camaro and a mullet. Same thang and a lot less trouble.....
Old 05-01-2004, 02:32 PM
Actually a small block chevy doesn't screw up the weight distribution of a 911 that much. They are lighter than a turbo motor, less complex, more powerful, etc.... There are lots of positives to a small block chevy, but taking a flat 6 out to put a small block in is a little weird. I think I'd rather just build a camaro or chevelle or something. It seem to me that building a 911 conversion RIGHT will end up pretty expensive, or you can go cheap and build a car that is not very well engineered which is part of the appeal of these things.
It's kind of like a fake rolex, some are nearly as good as the real thing and some are junk. The "junk" end of the scale is probably very heavy.
Either way, the important thing is that you like what you have.
Old 05-01-2004, 02:33 PM
geof33's Avatar
Short of the motor weight, that's EMPTY there is the water routing issue, there is the weight distribution issue, there is the MAJOR bad karma issue... ETC, ETC...
What is the deal with the V8 Hard-0n??? Is it becuase the V8 is SUPERIOR to the flat six? Not hardly. I own a big V8 in my truck where it belongs. Or a Vette or something like that. My dad's 65 vette is one Badass mo-fo. I wouldn't drop one in a 911 just like I wouldn't drop a flat 6 into a 57 Chevy. It's not natural...
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 05-01-2004, 02:36 PM
GrindingGears's Avatar
Originally posted by mikez
WATER SUCKS
mike you're speaking jibberish again....what the hell is water??
83 SC (gone) // 72 T (gone)
Old 05-01-2004, 02:38 PM
What a great idea - a thread on V8's in 911's. I'm pretty sure this is one subject that hasn't been adequately discussed on this board yet ........
Old 05-01-2004, 02:53 PM
