kqw kqw is offline
Upgraded Deck Lid and spoiler
Question...
Has anyone retro-fitted a 1984 - '89 Carrera with the Carrera 2 or 4 decklid with the oscillating spoiler.
If so, was it worth it? and does it work properly. I.E., raising at 50mph, retracting at 30 mph and the ability to manually keep the spoiler raised.
The Fox
Carrera
Old 05-05-2004, 06:35 PM
Make Bruins Great Again
Por_sha911's Avatar
The Search Button is your friend
Joe
Old 05-05-2004, 06:45 PM
kqw kqw is offline
Searching.......Searching.......Searching.......
no luck....
I'll call my wrench in the morning
The Fox
Carrera
Old 05-05-2004, 06:56 PM
Por_sha911's Avatar
Try this
Help! Installing 964 decklid on early car. Hinges and wiring?
Click the link in the 4th box down.
Joe
Old 05-05-2004, 07:03 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Here's some more:
New take on 964 dek lid install
1981 SC ROW Coupe
Old 05-05-2004, 07:09 PM
kqw kqw is offline
Thanks Joe,
The Fox
Carrera
Old 05-05-2004, 07:31 PM
Administrator
Jack Olsen's Avatar
It will not be speed sensitive unless you come up with a clever way to do it. Guys use a power window switch, sometimes in conjunction with a 'one-touch' load sensor device to make the wing go up or down with a single input. But they have to manually raise and lower it.
Compared to a flat decklid, it will reduce lift and improve cooling. It will not provide as much lift reduction as the bigger, fixed wings. The 964 (and later models) did not need as much help from a wing because Porsche had significantly improved the tub's aerodynamics.
I does look cool, however. And it's fun to raise it right before you punk someone at a stoplight.
Old 05-05-2004, 07:35 PM
Porsche's Avatar
I've done this. Check my sig link out.
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 05-05-2004, 08:25 PM
Hahaha, I can see that now, black beauty facing off against some ricer in a civic. The kid looks over, sees the tail going up and thinks, "Oh! Schtick, I am screwed, man!!"
Old 05-05-2004, 09:00 PM
