Help! Installing 964 decklid on early car. Hinges and wiring?
I am installing a 964 decklid on my '73 and am interested to see some hinge mod and wiring ideas before I start on my own. I have checked the threads but it seems like a tough search. The only hinge thread I could find is the one with the angle aluminum hinge mod. Not quite what I had in mind...
I know there is a wiring schematic floating around, but I can't seem to find it. Sure would save alot of leg work on my end. Jack? Thanks, Matt
'73 911 Targa / 2.7 RS spec |
Bye, Bye.
I PM'd Jack earlier this week for some help on this very subject. I will share any information I receive.
Elvis has left the building. |
Contact MA Shaw 1-714-730-6917.
I just purchased a set of adapter hinges they manufacture ~ $90.00 |
Here is "the" site, including wiring.
(BTW the 'AutoLoc' can be found cheap on eBay) http://66.34.72.138/howto/c2-lid/index.html
'04 BMW R1100S BCR '01 Audi TT RS gone but not forgotten: '87 911 Carrera '59 356 Coupe '66 912 Speedster '99 996 Ducati |
Somewhere in the Midwest
Matt, are you using C2 hinges? Or you stock?
I use C2 hinges and only havd to cut and weld the in one spot. Search Autoloc or 964 lid |
Administrator
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks so much to all who replied. All the extra ideas will be helpful. Unimog, thanks for the link to Tyson's diagram. Just last night I had hit on the idea of a power window auto controller, so it was nice to see and it's that much less to figure out.
I will be using a modified stock hinge. I'm looking for something that won't look modified when complete (angle iron or aluminum offsets, spacers etc.) I have already notched the stock hinge at the deck mounting face to clear the spoiler insert flange and relocated the one mount hole. I will be building a spacer to relocate the pivot end and will have pictures if anyone would like to see yet another idea on this subject . Thanks again, Matt
Ok, I tried fab'ing a spacer at the pivot end of the hinge, but the hinge hit the curved part of the deck lid opening keeping the lid from opening up fully. I decided that the most practical way was to offset the hinge 1-1/8". I tried to make the offset as close to the spoiler as possible so it would not be as obvious when open. I cut the hinge in halve and welded it back together with a piece of sheetmetal 1-1/8 inch wide. I tried to follow the hinge contours so it wouldn't be so hacked looking. Barely noticable when in place with the spoiler. I also shortened the hinge where it bolts to the deck and added a hole as the old lid had the holes farther apart. Works excellent, just needs a little paint and they're done.
Now, as soon as my Autoloc unit shows up... Matt
'73 911 Targa / 2.7 RS spec Last edited by Matt-Man; 03-07-2004 at 07:46 PM.. |
Oops, after the deck was opened, it had a little flex, so I added a gusset at on end of the offset...
Matt
Regarding the MA Shaw adapter that was mentioned, I tried these adapters and I couldn't make them work. From what I can tell, they are designed for the use of an older decklid on a 964. I guess for those who want to use an older tail + decklid.
Matt-man lets see a pic of the closed decklid and the tail extended.
Sam Gonzales '69 912 2.0 -6 power |
SCWDP- Shock and Awe Dept
Nice job, I've never seen it done like that, very clean. Are you going to put a shock on both sides?
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Thanks for the kind words...
Here are pictures of the lid assembled, open and closed. I will likely just double up the shock on the one side with a spacer. I think once the hinges are painted they will blend in fine... Matt
Outstanding
Matt,
VERY NICE. A very clean 'conversation' of the old style (non 964) hinges. It will look like it is straight from the factory, when it is painted. If you want the 'complete' look, use the pictogram switch pn# 993 613 203 00
In response to some inquirys I have had, I can convert anyone else's early hinges to adapt a 964 deck lid the same as I did mine and can finish out and color match if desired...
Anyone interested? Matt
hinges
Yes, I am very interested.
What must I do?. |
I am very interested too
X/A |
You can send me your hinges to modify, or if they are in use I will try to find a used set that I could send out on an exchange basis. Not sure on prices for a pair, but I'm thinking around $50.00 to modify (U-finish) or $100.00 color matched with PPG urethane ready to bolt on. Feedback?
I will try to finish out my own set ASAP and post a picture of the end product. Matt
Hinges
Matt,
Thanks. $50 is fair. My hinges are still attached to the under side of the engine compartment. My car has no deck lid on it at this time. Let me know how to remove them and I will send FedEx. I have a track event @ Pocono in less than 1 month!. Please send address. stlouis999@comcast.net |
