LinkBack | Thread Tools | Rate Thread |
Is it normal to hear a hiss while turning the engine during a valve adjustment?
I just completed my first DIY valve adjustment this weekend and was curious about something. I noted a faint hissing sound when I rotated the engine by hand. Is this normal? Do I have air leaking past valves or rings? Should I get a leak down test done? Am I panicking?
BTW, I left the plugs in while adjusting. Thanks
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C Last edited by Noel; 05-05-2004 at 08:48 AM.. |
It is normal if you do not remove the plugs - and IMO you should leave the plugs in to avoid carbon falling in the valve gaps when adjusting.
993 |
Sounds like you need a full rebuild and should sell you car as "parts car".
I will pay you $50 and cart your worries away. ......... it should be fine.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
You do not have permissi
It a good panic though. A loud hiss is a sign of good/normal cylinder sealing-so tight the trapped air is under pressure to escape.
There are three sets of rings and all normally have gaps when they are cold. The rings expand so the ends touch when hot, also the piston expands so it fills the cylinder. It's probably easier, but not necessary, to remove the plugs while turning the crank. What's important is the crank's at the right location and the gap is correct. Measure twice, cut once. A wire feeler gage is better than a blade because it's not affected by being at an angle, but the job is a back-breaker so I've heard. Get good kneeling/leaning cusion and take your time.
Meanwhile other things are still happening. |
Tim |
Thanks guys, I definately feel better.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Might be a snake living in the radiator. You should check tonight.
quote: "John, I've never seen one of these at .004" before. Can you elaborate?"
I was speaking hypothetically/ and don't think these are made for the difficult to reach boxer(or any) valve adjustments because they would bend/break too easily. At least in spark plugs the flat blade can commonly throw off an otherwise perfect drag/feel if it's at an angle, but a round gauge should not. I've never done a valve adjustment on a Pcar but it seems like an expensive mistake if the adjusting nut is torqued wrong or the vave is too tight(especially). One trick was after everything was set: try and slip a feeler gauge several thousands over in. It shouldn't go. Last edited by john70t; 05-05-2004 at 02:55 PM.. |
A wire instead of a blade could be more of a problem, since the foot of the thingy attached to the rocker arm swivels. The foot won't be straight, leading to a false reading. Maybe that's why the only alternative is the dial gauge method and not a wire.
Charlie Montara, CA 1970 911E 1950 VW |
poof! gone |
You know, I provide valuable insight into feeler gauges and you guys talk about snakes.
Charlie |
I suspect the car is commenting on your valve adjusting technique.
'80 SC |
