derek murray's Avatar
emachineshop.com... anyone tried it?
i came across this in a magazine... interesting, possibly
http://www.emachineshop.com
'70 911S 1002938
'70 Ducati Mark 3D 350
Old 05-05-2004, 11:22 AM
Senior Member
john_colasante's Avatar
That is one cool idea.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-05-2004, 11:24 AM
Hilbilly Deluxe
emcon5's Avatar
Some info here.
Tom
82 911SC Coupe
GTI Cup #43
Old 05-05-2004, 11:30 AM
You can say that again.
I will definitely try this out.
Warren & Ron, may you rest in Peace.
Old 05-05-2004, 11:37 AM
Do custom 930 FI bungs come to mind?
Old 05-05-2004, 11:56 AM
Oh this is dangerous... I was just thinking of things this morning I wished I could fabricate if I had access to a machine shop.
Thats what I get for watching Rides and wishing I had a 5-axis milling machine.
1968 911L
2004 Dodge Dakota SLT Plus
Old 05-05-2004, 12:15 PM
Oh Wow. What a great way to use the Internet.
I see a 930 injector block bulk order coming up.
And once you get over the initial setup cost, the price for higher quantities seems very reasonable.
Old 05-05-2004, 12:18 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
heck go one step farther.. wonder if you can get custom throttle bodies made up reasonably. just have them machine the body and plates, a little bit of delrin and a shaft....
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-05-2004, 12:30 PM
This business has to be doing great. A good idea for a slow machine shop for sure.
I made an inquiry into doing repeatable mandrel bent pipe. Let's see what they come back with.
Old 05-05-2004, 12:53 PM
Glasgow 911SC's Avatar
How can I transfer the pdf plans for Jorge's (targa dude) RUF style airbox cover into the CAD program? Needs to be redrawn? This could be interesting.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 05-05-2004, 01:02 PM
Sounds like the import feature is not reliable. It's reccommeded to use their tool from the start.
Would you use Vacuum formed plastic?
Old 05-05-2004, 01:06 PM
ART C.'s Avatar
the laser cut will have taper, as in the entry side will have a biger diameter on the thicher materials, but +/- .003 should not add cost to your designs.
Laserdyne/lumonics 1500w CO2
Fanuc/Anorad NdYag 350W
Makita cordless/HSS drill
Art
1971 911e Yellow cooling shroud
1995 GPZ1100
Old 05-05-2004, 01:25 PM
I guess if that'd be cheapest / easiest? It'd be interesting to see a proper product go through their system.
Chris
Old 05-05-2004, 01:57 PM
Did you see the second page of the thread? Showed a milled telescope adjuster thing-a-ma-jig . Pretty impressive. Took a while for delivery though.
Old 05-05-2004, 02:02 PM
WOW. Missed that link 1st time round. Very impressive. I have no idea where to start redrawing the airbox into 2D as that seems to be what they need to work from.
Chris
Old 05-05-2004, 02:13 PM
magic930's Avatar
Wish I had found this 3 weeks ago, would have possibly saved a few dollars.
I tried the software, it will be a time consuming task to make the 930 injection block shape! The injection hole will be the hardest part and most important the injection hole angle needs to be correct. If anybody is interested in trying it send me a PM and I can supply dimensions taken from a plastic block. I previously modeled this in a different program but it won't import.
Old 05-05-2004, 05:26 PM
A Quiet Boom's Avatar
Hmm, if I had seen this I might not have bought my mill...yeah right! hehe!
Seriously, they have a great concept.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 05-05-2004, 11:50 PM
This could be a great opportunity for some of the CAD/CAM types here to make a few extra bucks. Any takers?
Magic, Can you you import your model into a more mainstream program and from there into EmachineShop software?
Old 05-06-2004, 06:37 AM
FYI, They do not offer Mandrel bent tubing/Piping.
Old 05-06-2004, 12:47 PM
