emachineshop.com... anyone tried it?
'70 911S 1002938 '70 Ducati Mark 3D 350 |
Senior Member
That is one cool idea.
Hilbilly Deluxe
You can say that again. I will definitely try this out.
Warren & Ron, may you rest in Peace. |
Author of "101 Projects"
Nicely designed website too!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Do custom 930 FI bungs come to mind?
Warren & Ron, may you rest in Peace. Last edited by RickM; 05-05-2004 at 10:59 AM.. |
Oh this is dangerous... I was just thinking of things this morning I wished I could fabricate if I had access to a machine shop.
Thats what I get for watching Rides and wishing I had a 5-axis milling machine.
1968 911L 2004 Dodge Dakota SLT Plus |
Oh Wow. What a great way to use the Internet.
I see a 930 injector block bulk order coming up. And once you get over the initial setup cost, the price for higher quantities seems very reasonable.
993 |
heck go one step farther.. wonder if you can get custom throttle bodies made up reasonably. just have them machine the body and plates, a little bit of delrin and a shaft....
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
This business has to be doing great. A good idea for a slow machine shop for sure.
I made an inquiry into doing repeatable mandrel bent pipe. Let's see what they come back with.
How can I transfer the pdf plans for Jorge's (targa dude) RUF style airbox cover into the CAD program? Needs to be redrawn? This could be interesting.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Sounds like the import feature is not reliable. It's reccommeded to use their tool from the start.
Would you use Vacuum formed plastic?
the laser cut will have taper, as in the entry side will have a biger diameter on the thicher materials, but +/- .003 should not add cost to your designs.
Laserdyne/lumonics 1500w CO2 Fanuc/Anorad NdYag 350W Makita cordless/HSS drill
Art 1971 911e Yellow cooling shroud 1995 GPZ1100 |
Did you see the second page of the thread? Showed a milled telescope adjuster thing-a-ma-jig . Pretty impressive. Took a while for delivery though.
WOW. Missed that link 1st time round. Very impressive. I have no idea where to start redrawing the airbox into 2D as that seems to be what they need to work from.
Wish I had found this 3 weeks ago, would have possibly saved a few dollars.
I tried the software, it will be a time consuming task to make the 930 injection block shape! The injection hole will be the hardest part and most important the injection hole angle needs to be correct. If anybody is interested in trying it send me a PM and I can supply dimensions taken from a plastic block. I previously modeled this in a different program but it won't import.
David |
Hmm, if I had seen this I might not have bought my mill...yeah right! hehe!
Seriously, they have a great concept.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
This could be a great opportunity for some of the CAD/CAM types here to make a few extra bucks. Any takers?
Magic, Can you you import your model into a more mainstream program and from there into EmachineShop software?
FYI, They do not offer Mandrel bent tubing/Piping.
