thrown_hammer's Avatar
Question High idle issue with a 3.2
My car has always had a high idle when I come to a stop. Around 1200-1300RPM. If I blip the throttle it settles down to around 1000-1100 RPM. I noticed if I take the oil cap off it drops to 850-900 RPM which I assume is normal? Put the cap back on and it jumps back up. What does this mean? For reference its a 1986 US 3.2 in a 1973 911.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 05-06-2004, 06:39 AM
Friend of Warren
Shawn, I fought this battle for about a month after I rebuilt my 3.2 over the winter. It is normal for the rpm's to drop when you take off the oil cap. After much checking of the entire system it turns out that my idle adjusting screw was turned out way to far. I had a burnt valve and maybe the idle needed to be adjusted to compensate for that in the past. I ended up turning my idle screw in about 9 turns!
Kurt V
Old 05-06-2004, 06:46 AM
Ahhh! This engine was rebuilt before they put it in the car. I wonder......
Where is the idle adjustment screw?
1975 911S (sold)
Old 05-06-2004, 06:50 AM
Shawn:
This was just recently discussed here and should give you what you need.
How do I test Idle Control Valve
Tim
Old 05-06-2004, 08:14 AM
GFCC
Jeff's Avatar
Shawn, Look at this thread.
News Flash... Fellow Pelican solves hanging idle mystery!!!
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 05-06-2004, 08:15 AM
Jeff,
I think that might be it..... Do you have any photos of the switches? Or a detailed desciption of what it looks like or location? Thanks.
1975 911S (sold)
Old 05-06-2004, 08:38 AM
Detached Member
Hugh R's Avatar
Did you see this post today? News Flash... Fellow Pelican solves hanging idle mystery!!!
Hugh
Old 05-06-2004, 09:55 AM
Hugh,
Yeah that is the thread Jeff pointed out. I subscribed for future reference.
1975 911S (sold)
Old 05-06-2004, 10:25 AM
GFCC
Jeff's Avatar
Shawn, I'll go take a picture and have it up in a little while.
Jeff
Old 05-06-2004, 10:29 AM
GFCC
Jeff's Avatar
Shawn, Remove the plug in the photo that I mark with orange. Check continuity between the two switch terminals. There should be continuity when the switch is at rest and it should not have continuity when the throttle is moved from idle position. When you return the throttle to idle you should have continuity once again. Try it a few times. If you don't have continuity at idle on any of the trys, you have found your problem. The fixes are...
1. try spraying idle switch with contact cleaner (electical not eye ball )
2.adjust clearance between throttle arm and switch
3.replace switch
P.S. - the switch is located on the opposite side of the throttle body than the plug. It is a little black box that the throttle arm will rest near (just trace the wire and you will find it)
Jeff
Old 05-06-2004, 10:54 AM
Jeff,
Thanks! Now for a stupid question....Do this with the ignition on but the engine off?
1975 911S (sold)
Old 05-06-2004, 12:22 PM
GFCC
Jeff's Avatar
Shawn, Engine off. I don't think it matters if the key is on or not.
Where in Michiana are you? I will be traveling back to that part of the country this summer.
Jeff
Old 05-06-2004, 12:38 PM
Warsaw, IN. Orthopedic capital of the world!
1975 911S (sold)
Old 05-06-2004, 01:06 PM
Are you sure it's not just overjoyed to be blue ?!?
Great looking results BTW...
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 05-06-2004, 03:03 PM
