What is Weber 40IDTP3?
I am rebuilding my Webers and I don't recall the eact part number, but instead of 40IDA3C, which is what I expected, the number started with 40IDTP3.
What is the difference?
Jim Chatfield
1972 911T
1999 Lexus RX300
Old 05-10-2004, 02:37 PM
Grady Clay's Avatar
The nomenclature I see is “40 IDTP 1 3 C/3C1”.
It was delivered on a ’71 911T except USA engine
Types 911/03 and 911/06.
If you need I can send a larger image or type out the specs.
Best,
Grady
Old 05-10-2004, 02:57 PM
Re: What is Weber 40IDTP3?
I think they're pretty much identical, with the exception of the jetting. The IDTs were originally fitted to T engines and the 914/6.
Old 05-10-2004, 02:59 PM
Grady:
Could you send a larger pic, I cannot quite read the chart. I tried to blow it up, but it was then to fuzzy to read.
Thanks,
Jim
Jim Chatfield
1972 911T
1999 Lexus RX300
Old 05-10-2004, 03:09 PM
Grady Clay's Avatar
Try this one.
The two line captions that are obscured by a greasy fingerprint
are; "Idle air bleed" and "Pump inlet valve."
Best,
Grady
Old 05-10-2004, 03:43 PM
