I'm not here.
K. Roman's Avatar
Can Someone help me start my car?
I went into my garage today, hoping to take a drive after the rains here in SF, and my car wouldn't start. The battery is fine, lights work, fuel pump turns on, fuses look OK, I hear a click in the engine when I turn the key and that is it. Does anyone have any suggestions to where I should look?
I'll be online waiting, thanks.
K.
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?)
Old 03-24-2005, 12:07 PM
A single click means your battery is run down. Charge it and fire it up.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-24-2005, 12:14 PM
ckissick's Avatar
Could be a bad starter.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 03-24-2005, 12:15 PM
I'm not here.
K. Roman's Avatar
I'll try charging it, but this seems a little strange since I didn't leave any lights on.
ckissick: How can I check on if my starter is bad?
Old 03-24-2005, 12:18 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Batteries can drain over time. Has it been parked? If so, how long? Can you remove the battery and have it checked?
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-24-2005, 12:21 PM
I'm not here.
K. Roman's Avatar
I have a friend who will be bringing over his plug in the wall battery charger. Hopefully we'll see if that is the prob...
The car has been sitting for about 1 week.
Old 03-24-2005, 12:24 PM
I would try the charge first but usually is other things such as a bad ground or starter solenoid I think. The ground that everyone seems to forget to clean, (well at least no one here told me about it and I just happen to come across) is a ground cable that goes from the panal your CDI is on to the body. Try cleaning all grounds before you buy anything. Check the battery cables are clean and tight and then one coming off the CDI plate is accessible so good place to go next, just remember to clean both ends on the cable and where they run into. Wires to and from the CDI and where they run to (Ignition coil, distributor). Tranny one is last due to need to lift car to accesss.
Good luck.
Old 03-24-2005, 12:28 PM
Small electronic device like radio with memory can drain the battery after car been seating for a while, depend on the battery condition, older battery darin quicker
TC
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 03-24-2005, 12:29 PM
ckissick's Avatar
The only way I know is to replace it. But first, you've got to eliminate other possibilties. You said the battery is OK, but I wonder. Even if nothing was left on, if it's old, it could have gone bad. It would still charge lights and such; startiong the engine required the most juice, so that may be the only thing that the battery can't do. My bet now is the battery.
If you're like me, you've waited almost 2 weeks for the rain to quit. I drove mine for the first time in awhile today.
If you have a multimeter, check the battery charge. It should read 12 to 12.5 volts. Try jumper cables.
You could tap the starter with a hammer (stuck solenoid?) Maybe the starter gear is jammed in the flywheel, so put the car in gear and push it back and forth. These things have worked for me in the past on other cars.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 03-24-2005, 12:30 PM
RETIRED
Joe Bob's Avatar
Fully charge it....the little 2 amps thingys take WAY too long. Go down to Sears and get the 2-10 amp charger. Anyone with a 356, 911 or 914 needs one.
After fully charged it should be 12.5 volts at the terminals.
When running check voltage again at the terminals...should be 13+, and 13.5-14 volts at 2500 rpms.
IF IT STILL doesn't start after charging....meaning it just clicks....check your connections and GENTLY tap on the round sausage like thjing on the side of the starter...that's the solenoid.....it may be stuck....try again.
2012 ML350 3.0 Turbo Diesel
Old 03-24-2005, 12:43 PM
Originally posted by ckissick
...If you have a multimeter, check the battery charge. It should read 12 to 12.5 volts. Try jumper cables.
Ya, what ckissick said is what I'd do first. It doesn't take a big drop in voltage for a starter to refuse to turn. (mine once read 12 v and would barely turn.) Since the car sat for a week in not so hot weather, that's what I'd suspect.
But let's say your battery is fine and even a jump start won't make it turn - then the hammer trick on the starter sometimes works.
I once had a starter go bad - it had a flat spot and the no start was intermittent based on where the starter stopped turning. If the armature was lined up at the flat spot, no go.
-Steve
'87 Carrera Targa
Old 03-24-2005, 12:54 PM
Student of the obvious
LeeH's Avatar
I've had two interesting events with batteries this week.
I bought an old Saab to fix up and sell. It had been sitting for a couple of years. I charged the battery and was pleasantly surprised that it was showing 12 V after the charge. Well, that's not under load. It wouldn't even turn over. I took it to AutoZone and they tested it. Yep, 12 V until they put a load on it... then 3 V!
Then yesterday my wife's Mazda 3 was turning over slowly. The car was purchased new less than a year ago. Took it in today and had it tested. The battery was bad. They had to install a new one.
Lee
Old 03-24-2005, 01:01 PM
Re: Can Someone help me start my car?
Originally posted by K. Roman
I went into my garage today, hoping to take a drive after the rains here in SF, and my car wouldn't start. ?
K.
Drove mine last night. What car!
Old 03-24-2005, 01:18 PM
911mot's Avatar
Turn the headlights on and try to start car. If headlamps go very dim when you turn key, battery is flat or bad battery connections.
If the headlights do not go dim check main starter feed wire up under car. Sometimes just grasping the cable and giving it a good wiggle can temporarily get you going.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 03-24-2005, 01:23 PM
I'm not here.
K. Roman's Avatar
So, the first thing that I did was to use the battery charger on it....It started fine on the 50volt setting and I drove the car for about a half an hour. During my drive the lights went dim, bright and as the engine fluctuated as it idled, so too did the lights. I also noticed the tachometer bouncing up and down when idle, and the engine wasn't being revved. I drove it back to my house and shut off the engine. The car wouldn't start again or turn over so I just left it there in that state. What gives? Do I need a new battery?
Where should I buy one, and what should I get?
TIA,
K.
Old 03-25-2005, 12:41 AM
a911's Avatar
Altenator?
"88" carrera
"02" tt roadster (wife) sold
"04" jaguar x-type
"04" kawasaki zx10r
"05" yamaha mayesty
"05" A3 sportback
Old 03-25-2005, 01:37 AM
Had the same issues a few weeks back=Alternator..fine since fixs
Rika
Old 03-25-2005, 05:17 AM
Third vote for your bad Altenator
Old 03-25-2005, 06:31 AM
RETIRED
Joe Bob's Avatar
Yeah...prolly the alternator. But it sounds like you used the battery charger to JUST start it. You should have FULLY charged it.....even with a GOOD alternator....it will put strain on the alt trying to bring up the battery.
Alts are NOT designed as battery chargers...they are battery maintainers....
If you had charged the battery fully, it would have run fine for many hours without the headlights on....I had a dead alt and made it back from AZ to the coast of CA on battery power...
Old 03-25-2005, 06:38 AM
JOT MON ABBR OTH
Four to the alternator.
Old 03-25-2005, 06:40 AM
