canna change law physics
red-beard's Avatar
69 S Mech advance Bosch Distrubutor advance curve
I am replacing my Marelli with a Bosch...
The engine is now a 2.7 with S cams so I went with the 69 S version. Does someone have the advance curve for the distributor.
Bruce's book says set the advance to 30 BTDC at 6000 RPM. Any thing else I should know?
James
Red-beard for President, 2020
Old 05-13-2004, 06:30 AM
Grady Clay's Avatar
Try this:
(C) 1969 Dr.-Ing. h.c.F.Porsche K.-G
Remember the engine RPM is double the distributor RPM.
I assume this is single plug.
Do you have knock sensing? With care and the big bore,
you might be able to get away with more advance.
Best,
Grady
Old 05-13-2004, 06:54 AM
red-beard's Avatar
2.7 RS spec with relatively low compression, under 9.
It's funny, they only had "S". And it looks like the only difference is the rotor. SO hopefully that means I get a cap and rotor with the thing.
$325 for a rebuilt.
James
Old 05-13-2004, 06:59 AM
