Guest
Posts: n/a
What color is this?
I striped my 1973T down to the tub, I pulled out all the wiring, gas tank, suspension... I noticed that what i thought was conda green is not. It looks more like viper green. The car was painted by the previos owner. It was paintedconda green. I dont mind because I like Viper green better than conda green. The code on the door reads:
225-8-2 I also wouldnt mind seeing some of your viper green cars if you have pics. Thanks! Here is what she looked like before the teardown.
Yes paint code 225 is Viper Green which was a 1972-73 color. Conda green is an earlier color of almost the same shade. Viper and Conda Green are some of my favorite early 911 colors.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
Guest
Posts: n/a
Thanks Brian. I only noticed the difference in color when i took the interior out. Also in the front trunk. Viper green will make a great color for my RS clone.
I have a 74, which looks very similar in green to the above pic. Which green do I have?
Guest
Posts: n/a
Judging by your profile posting it says emerald green
Check your drivers side door and get the #s on the black and silver plate below the the pin switch. Then post your findings and some fellow pelicanite will help you with you question. Thats what i did and got my answer. Joe |
