-   -   What's That Sealing Stuff Called????? (http://forums.pelicanparts.com/porsche-911-technical-forum/162678-whats-sealing-stuff-called.html)
joeycatt 05-12-2004 07:51 AM
I removed the fenders from my SC....there was some kind of gummy "stuff" between the fenders and the body structure, along the seam. It was like a gummy tape substance that sealed the edge between the fenders and the structure....I cannot find it listed in the Pelican parts lists....
Anyone know what this tape or stuff is called? Is there any suitable substitute for it, if it's not available now?
JMPRO 05-12-2004 08:01 AM
Go to www.eastwoodco.com they have all that sealing gunk
Jerry
RickM 05-12-2004 08:41 AM
Jerry's link isn't working so here's all the info you should need..... http://forums.pelicanparts.com/porsche-911-technical-forum/105652-fender-installation-putty.html?highlight=putty
Jim Sims 05-12-2004 08:45 AM
If you want the OEM material:
The fender packing is also know as Terostat ribbon 2mm thick x 25mm wide, sold by the meter; the Porsche part number is 00004312900 or Pelican U-043-129-00. Pelican lists it for $27.75. When I ordered it from the Porsche parts system I recieved a roll which was significantly more than a meter in length; plenty to do a car maybe enough for two cars. Jim
JMPRO 05-12-2004 09:28 AM
I corrected that link
Jerry
